Old 10-21-2009, 02:36 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by 3-Wheeler View Post
Of course don't ask about how much time the sanding/glazing/priming and painting will take.
Jim: this is why I ruled out a foam/fiberglass approach. The kammback is a resin-soaked cardboard/fiberglass sandwich, and I spent 75% of my time trying to make it look nice after it was functionally done. The body work tested my patience .
Also, I don't think the finish turned out all that great relative to the time I spent. To add insult to injury, it's peeling/bubbling in spots!
Old 10-21-2009, 03:06 PM   #12 (permalink)
...beats walking...
...I'd get a replacement backlight/hatch assembly from a junkyard and attach the boattail permanently to IT, then simply bolt / unbolt the whole she-bang to do A-B testing.
Old 10-21-2009, 03:09 PM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
But then it wouldn't easily fit for storage in the car...
Old 10-21-2009, 03:14 PM   #14 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
I think the point is that in this case, it may be much easier to slap something on there permanently to test it and see if the results make it worth the time and effort to make a fancy one that will detach and fit into the hatch. A whole hatch may be pretty cheap too depending on the junkyard. I know there are plenty of that generation hatches in the yards around here.
Old 10-21-2009, 03:44 PM   #15 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
I've spent a silly amount of time standing around looking at the back of the car.
Heh, I think we've all been there.
Can't wait to see what you come up with. I think you will find that the internal bracing can be minimal if you let the coroplast skin carry the load; i.e. monocoque construction.
-Terry
Old 10-21-2009, 05:52 PM   #16 (permalink)
PSmodder lurker
Inflatable boat tail
Your requirement of having the boat tail stowed in the car was a challenge. We had earlier concepts of rigid or semi-rigid boat tail appendages mainly supported by extended hitch connections. So a folding inflatable could be attached ala bike rack straps & a rigid spar to hold the rear lights/license assemblies. The inflatable form could theoretically have the optimum airflow shape. Inflatable aerospace tech has been updated from earlier Goodyear airplane studies. The exciting 'Mars airplane' studies depend heavily on reliable inflatable airfoil engineering solutions. The tech has already been used in the Pathfinder projects.
Goodyear have taken early tests & concepts of inflatable airplane platforms. A compact rescue package designed for downed pilots/operators that could be air-dropped. They could then be deployed & flown to their freedom and back to friendly lines. However watch out for catastrophic deformation at extreme speeds.
Old 10-21-2009, 07:54 PM   #17 (permalink)
I've thought that a junkyard hatch would be a good thing. Speaking just of the Kammback: I could integrate it better into one that I didn't mind welding/cutting up/bondo-ing/etc. It could be lighter, plus I could lose the rear glass and enclose with plexi.
I'll probably skin the boat tail with cardboard for testing before doing anything more complicated. (removable panels, coroplast)
EDIT: but I won't be able to work on this any more until the weekend at the earliest.
Cd asked me via PM if I knew the car's current Cd. I don't. I went out one day this summer to do the Instructables "measure your Cd" coastdown test, but the numbers I got didn't fit very well in the curve used to figure out Crr and Cd, so I didn't bother finishing it.
Old 10-21-2009, 08:11 PM   #18 (permalink)
Botsapper: inflatable would be fantastic.
Old 10-22-2009, 01:14 AM   #19 (permalink)
aero guerrilla
Piwoslaw's Avatar
Inflatable boattail
Old 10-22-2009, 02:07 AM   #20 (permalink)
PSmodder lurker
These ideas just keeps going around. Let's see some eco-prototyping!!!
FuelSaver by ATS™
boat tail, testing
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
