Old 11-19-2009, 09:05 PM   #81 (permalink)
90 day: 51.82 mpg (US)
Passenger side and bottom left to do. Oh, and better not forget the camera boom before I seal it up.
Even only half covered, I'm cautiously optimistic about how rigid it already feels. I also did some cross-triangulating on the frame inside - will get a shot of that tomorrow before I finish the skin.
EDIT: also added another picture of the four bulkheads in place:
back here in post #74.
Old 11-19-2009, 09:17 PM   #82 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
That's one nice looking boattail. Keep it up! Are you going to do an A-B-A test of the CAD?
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-19-2009, 09:21 PM   #83 (permalink)
My cruise control is still busted, so I can't do as-controlled-as-possible testing.
But I'll likely try it anyway - it'll also be a test to see how consistent & steady I can hold my speed.
I could just do coastdown comparisons (they pretty much remove the driver from the test - which is the goal), but I want to get an idea of the actual fuel economy impact, and coastdown runs don't tell me that as directly.
Before any of that, though, tuft testing to make sure it's got attached flow.
Old 11-19-2009, 10:00 PM   #84 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Are you going to see what the new drag coefficient is when you get everything worked out ?
Also, did you ever consider adding a trip strip on you rounded tail lights ? ( when you are in 'stock' configuration . )
Old 11-19-2009, 10:30 PM   #85 (permalink)
Yeah, once ALL the aero mods are done, I'll probably attempt to figure out Cd.
Trip strips: yes, I've thought about them - for the bumper as well. I had the idea that I could incorporate some hard edges on the bumper corners as a mounting point for the boat tail.
Old 11-20-2009, 12:23 PM   #86 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Good job so far. Yeah it doesn't take much for rigidity when you use sheets of material. Same way basically piece of painted cardboard keeps an entire entertainment center square. I braced mine to be totally rigid before adding any panels, to keep the load off them and prevent popping of welds. But if I had better welding equipment, I could have eliminated a lot of cross bracing and saved some weight.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-20-2009, 02:26 PM   #87 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Where do you plan to mount the camera ?
Besides the obvious views that you want, such as the sides of the tail, it would be interesting to see how much turbulence is on the very back and underside. ( like behind the wheels )
When do you plan to add minitails to your mudflaps ?
Also, I know that you didn't get good results with your bellypan test, but as you mentioned, the cardboard was drooping down during the test. Do you ever plan to redo the test ?
And one more thing - Do you remember the post about the U.C.Davis Taurus that they aeromodded ?
It seems like it would be a simple thing to create a concave area around the center of the back end. It can't hurt ( might even look better too, rather than have a totally flat surface ... a little style ) If you remember, the aero guy stated that the concave area created a small vacuum that resulted in a smaller wake.
Old 11-20-2009, 02:52 PM   #88 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
like one giant golf ball dimple. Interesting ....
Old 11-20-2009, 03:36 PM   #89 (permalink)
Not quite the same thing as a golf ball dimple. (Man, everyone loves golf ball dimples!)
Cd: will answer questions later on.
A couple more pics of progress:
Above: cross bracing the inside. (Yes, those white pieces are cardboard - really stiff "angle iron" cardboard.)
And below, two views of the completed driver's side and top... now with self-supporting goodness!
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
max_frontal_area (11-24-2009), NeilBlanchard (11-20-2009), Piwoslaw (11-22-2009), theycallmeebryan (11-20-2009)
Old 11-20-2009, 03:44 PM   #90 (permalink)
Grrr :-)
Nerys's Avatar
hey man thats starting to look very cool. a quick shot of BLACK spray paint and it will even have a nice 20ft finish.
boat tail, testing
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
