Old 12-03-2012, 02:13 PM   #81 (permalink)
That is actually something that will be changing. I no longer need to make this easily removable. I wanted it to be so I could take it off for warmer weather. With the addition of my automatically actuated grill block I won't need it to be easily removable. So, I am now open to more mounting options.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (12-04-2012)
Old 12-03-2012, 07:18 PM   #82 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
California98Civic is correct. I don't want anything protruding. I want it to look like an OEM body panel. Usually I can deal with fasteners and zip ties (that is what is on the car now). But, I wanted to make this one as close to a nice flush 'pretty' panel as possible.
Sorry, that was confusing. I meant to put the eye hooks and stuff on the back of the block. The front will look the same; it will just be quicker and easier to deal with the mounting solution.
Old 12-04-2012, 08:26 AM   #83 (permalink)
Thats a pretty good idea.
This is my current mounting idea now. The picture is a cross section of the grill area. The thought is to use a couple tapered wooden blocks to locate the grill block on the grill. These would be glassed to the back of the grill block. I could screw Sven's eye hooks into the back of the blocks and run a rubber band around the grill slat to hold it in or something. The cloth / rubber covering just protects the paint.
Name:	grill block.jpg
