Go Back   EcoModder Forum > AltModding > Saving@Home
Old 02-11-2015, 08:44 PM   #1 (permalink)
Pulse and... and...?
Had a notion to try something new- hypermiling the thermostat. Just like I've been doing for years with my nat-gas water heater (always set on "vacation" until I go "click it on" 5 minutes before a shower). What took so long for this idea to form?
I already have a programmable 'stat but still the forced-air natural gas furnace has what I think are annoying and inefficient quick on/off cycles. Seems like nothing in the HVAC system ever gets a chance to really get up to a nice warm temp that's sustained for any length of time.
I've long known I'm quite comfortable after I turn in to bed at temps down to the 30s F what with the flannel sheets and foot-thick stack of quilts. My nose feels the cold but it's not a comfort issue like cold feet and hands- it's ignorable and can fall asleep anyway.
So for the last few days I've been shutting the furnace OFF at the 'stat at dusk, not to be turned on again until late morning or noonish the next day. I figure one good pulse "zone"- to reheat the air and the mass of the house and contents- at the time of day when outside temps and solar gain are the greatest should be quite a bit more efficient. Haven't figured out what to call the "glide" phase yet...
Today the high/low outside was 5/-5 F and the predicted temps this week are even colder, perhaps -30. That will be a good test.
ME_Andy (02-12-2015)
Old 02-11-2015, 09:18 PM   #2 (permalink)
I wore out ignitors once a year untils I upgraded to an adjustable swing t'stat. Been 10+ years since I've had to replace the ignitor. I'm set at 54 overnight, 60 from 6-7am back to 54 am till 5 pm and back to 60 till 10 pm. Runs for about an hour straight in the morning, and again in the afternoon, occasionally I bump it in the evening to 61 to for a 30 minute run.
Old 02-11-2015, 09:37 PM   #3 (permalink)
This should actually be easier on igniters.
Old 02-12-2015, 10:08 AM   #4 (permalink)
I had to replace my combustion blower and primary heat exchanger in the first 5 years, I think it was related to short cycles as well. I see a 1 degree swing each way with where I have the adjustable swing set 4 of 5 I think. I have 2 t'stat, a Ritetemp on the LP forced air, and Climatouch on the hot water floor heat.
Climatouch has energy monitors, can input energy cost and it will calculate $. I just input 1 and it just tells me how many hours the pump runs, when the pumps running the water heaters running.
Bigger swing is way better for cooling season as well, less starts, longer runs and more chance to get the air wringed out.
The Following User Says Thank You to roosterk0031 For This Useful Post:
Frank Lee (02-12-2015)
Old 02-12-2015, 10:44 AM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I can picture the wife now, "pulse glide, that's your answer to everything".
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
Frank Lee (02-12-2015), UltArc (02-12-2015)
Old 02-12-2015, 01:51 PM   #6 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
I can picture my future wife: "no F-ing way, it's too damn cold in the house!"
How about calling it "freeze and thaw" lol
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
UltArc (02-12-2015)
Old 02-12-2015, 02:13 PM   #7 (permalink)
Absolutely- no woman would go along with this. I have no such burden.
Was -15F overnight; only got down to 40 inside with a 13 hour... ummm... glide. My nose wasn't even cold.
A bigger swing from the 'stat- that's what I need.
Old 02-12-2015, 10:18 PM   #8 (permalink)
Don't think there's a t'stat with a swing big enough, but a little programming will do. How low will it go while still in heat mode. My Ritetemp goes down to 45, climatouch 41. Decide how long you want the heat to run in the morning. Furnace kick on is my alarm clock, 5 minutes later my bathroom's warm. Have to experiment with how long you want it to run in the morning. It was 2 outside here this morning and furnace didn't run overnight, -15 it will though at least once. Going to go set the swing as far as it goes and see how I like that.
Make it run twice a day, 30-60 minutes in morning, and same in afternoon if solar gain doesn't satisfiy it. Which is what I do on weekends, if I get cold I'll go bump it, otherwise the sun usually keeps it happy.
EDIT: was way off with my swing, it was at 2 of 6, bumped it to 4.
Old 02-12-2015, 10:24 PM   #9 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
We do 3 pulses per day in our 800 sq ft home and it stays pretty reasonable. Hardly ever gets below 55 even at night when we leave it completely off.
Old 02-12-2015, 10:33 PM   #10 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
insulate your t-stat, i imagine one of those styrofoam looking faucet covers would probably do too good of a job... maybe hang a cardboard box over it, if thats still too much add holes
The Following User Says Thank You to 2000mc For This Useful Post:
roosterk0031 (02-12-2015)
