Old 03-05-2015, 01:48 PM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Tire that makes electricty
https://autos.yahoo.com/blogs/motora...134602398.html
Tire that makes electricity???
The first, dubbed the BH-03, combines two fairly advanced technologies to generate electricity from the tire itself that could help recharge electric vehicle batteries on the road. A weave of thermoelectric fibers transforms the heat generated by the tire's friction with the road into energy, while piezioelectric material does the same using changes in the tire's shape as it moves. Goodyear didn't suggest how much energy such a set of tires could potentially create, but said if put into production could ease EV owners' range anxiety.
Pressure Gradient Force
The Positive Side of the Number Line
Old 03-05-2015, 02:04 PM   #2 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Interesting concept. That specific tire/wheel combo pictured wouldn't last long in a real driving environment with potholes curbs etc.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 03-05-2015, 02:24 PM   #3 (permalink)
I wonder what kind of rolling resistance they will wind up with?
Remember, you can also put linear generators on your shock absorbers. Those don't make enough power to bother with, though. This may turn out to be a similar deal...
-soD
Old 03-05-2015, 02:49 PM   #4 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Potholes would make more electricity due to the tire's deflection lol
How does it transmit the power to the car? A bare end of a wire rubbing on a stationary plate at the center hub?
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 03-05-2015, 06:55 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Chances are the friction of that would cancel out the gains. It would have to be via two electrically isolated bearings, or possibly some form of magnetic induction set up.
Old 03-06-2015, 01:13 PM   #6 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
It takes work to generate electricity. Every watt of electricity generated is added rolling resistance. The total increase in rolling resistance is equal to the electricity generated divided by the efficiency of generating that electricity.
It's a variation of the old perpetual motion scheme of connecting a generator to the front wheels to drive an electric motor on the rear wheels.
The Following 3 Users Say Thank You to JRMichler For This Useful Post:
Joggernot (03-07-2015), NeilBlanchard (03-06-2015), pgfpro (03-06-2015)
Old 03-06-2015, 01:36 PM   #7 (permalink)
I think that regenerative shock absorbers have a better prospect at being practical.
The Following 4 Users Say Thank You to NeilBlanchard For This Useful Post:
gone-ot (03-06-2015), IamIan (03-07-2015), JRMichler (03-07-2015), pgfpro (03-06-2015)
Old 03-06-2015, 06:33 PM   #8 (permalink)
Team Turbocharged!
Pickups
I agree that it doesn't seem practical. But the tyre is deflecting anyway, using this deflection to generate electricity will add resistance to the tread deforming, basically making the tread stiffer and reducing rolling res. Problem for us would be as you raise tyre pressure the energy generated will drop.
Old 03-07-2015, 03:47 PM   #9 (permalink)
JRMichler's Avatar
True. A shock absorber converts suspension movement into heat by churning a fluid. A regenerative shock absorber would convert that movement into electricity instead of heat.
The downside is that smooth roads would generate very little electricity, and regenerative shocks would be heavier than standard shocks. Regenerative shocks would be perfect for somebody driving on washboard gravel roads.
Old 07-05-2015, 11:48 AM   #10 (permalink)
90 day: 30.18 mpg (US)
Here is a different method: New nanogenerator might set energy-generating car wheels in motion
pgfpro (07-05-2015)
