Hygienic Wall Cladding 8'x4' 8ftx4ft 8x4 pvc sheet upvc sheet White gloss finish | eBay
I've found a source of PVC sheet on eBay - this is only 2 mm, and I've asked them for a price for 3mm (also what colours are available)
But just wondering if this is likely to prove a good material for use as an under-belly pan, and for a possible Kammback?
Is it likely to be stiff enough not to flex too much? Does it have a tendency to shatter?
I'm guessing Correx/Corroplast would be easier to cut...
I'm thinking this product might work for side-skirts...
http://www.ebay.co.uk/itm/1-x-5metre...item35b9968f1e
TIA
Later:
They just told me that 3,mm sheet is UK£45 per sheet, and they have grey in 3mm but it is UK£60 per sheet - ouch..
