Old 04-30-2013, 11:45 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
you can look at the grill block I did on the Infiniti (link in my sig)
yeah, there was an aero benefit, but it was a pretty smooth design. And i kept it on all yr.
But I also added a 7 & 9 inch push fans to the radiator.
As you can see in my link though, It's about testing.
I always used the same 10 mile strip of freeway to test stuff. The scangauge lests you reset after each run.
My Kia also showed an improved mpg with a complete lower block. I partially blocked the upper because I didnt want to run hotter than 220.
While it is a V6....it is a VERY whimmppy V6.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-30-2013, 11:47 PM   #12 (permalink)
mcrews's Avatar
Originally Posted by Cobb View Post
Grill blocking helps with aero,
cobb,
VERY niice job on the black and following the lines, I really like it!
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-30-2013, 11:54 PM   #13 (permalink)
cbrer's Avatar
Hardbody - '95 Nissan Pickup XE-V6
Muchas gracias mi Amigos!
This is all great thinking from those who have been there, done that, and...well you know the rest!
