Old 03-18-2009, 10:58 PM   #1 (permalink)
C3Killer - '94 Geo Metro Baller Mobile
90 day: 55.44 mpg (US)
Will raising my compression raise my MPG??
Sadly the rings in the 3rd cylinder went recently in my '94 Metro. Before this, I was getting up to 62.38 mpg. While planning an engine rebuild, I am considering getting the pistons balanced, engine blueprinted and balanced, the crank balanced and knife edged. Should run SMOOTH AS GLASS! Anyways, will shaving 1mm off the head (to raise my compression) give me any mpg's? Any input would be taken into consideration. Thanks for all the good information that this site has given me to get up there in mileage. Even though the gas price went back down. C3.
Old 03-18-2009, 11:29 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Theoretically it should raise the efficiency of the engine. Will of course need tuning and lots of work, with probably no conclusive results,
Old 03-19-2009, 12:19 AM   #3 (permalink)
Also add a water injection system.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-19-2009, 11:24 AM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
CoyoteX shaved his Metro's head and advises against it (pinging).
See starting @ post 10 in this thread: http://ecomodder.com/forum/showthrea...html#post87384
Possibly shaving less than he did is OK - he took 0.40 off. See http://www.teamswift.net/viewtopic.p...it=shaved+head
Old 03-19-2009, 04:46 PM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I think you would be better off adding an XFI cam instead.
raised compression will require a higher octane fuel or for the engine to be run cooler, or both, making sure that the head and block are flat and mate together perfect is as far as I think is a good idea.
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Mark your MPG on your windows and raise awareness! Chris D. General Efficiency Discussion 119 07-23-2013 11:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The 66.6 mpg challenge groar Success Stories 3 01-04-2009 09:05 PM
