Old 07-25-2009, 05:04 PM   #1 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Wiper cover build
Hi there fellow Modders,
I have taken the plunge with my 96 VW Golf MK3 and started a few aero mods. I am getting roughly the manufacturers average of 38mpg (in "wierdy US mpg") from the old school D-turbo motor, so it's time to make that better.
I am starting with the low hanging fruit for FE (service, tyre pressures, light aero mods) and the first aero mod will be my wiper shield. After seeing them on a few newer models as standard, and retrofitted to the Audi Biogas car (see here). I decided to take the plunge.
I helped myself out by buying some low profile wipers (see attached pictures) and re shaping (read "bending") the wiper arms to sit as low as possible.
I then did the usual cardboard mockups, and jigsawed the shape out of an old plastic road sign that has been lying in my street for weeks.
You can see the rough shape in the second pic. I should have it sprayed and mounted this weekend, when the epoxy gluing the two pieces together has set.
Any comments are welcome.
ID:	3912   Click image for larger version
Old 07-25-2009, 06:44 PM   #2 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Smile seeing as how you cant really park them any lower
you will do well having that deflector/shield. just keep the angle as low as possible to not upset the benefits. i was going to make one too until i realized i could park my wipers a LOT lower and actually have them UNDER the hood. i will try and post pics.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 07-25-2009, 07:13 PM   #3 (permalink)
I did look at lowering my park position but it went way too low, getting caught up in metal and rubber ridges under the bonnet.
Good advice on the angle, I will try and set them as low to the wipers as possible (hence the bending of the arms). Hopefully it won't look to shabby and I will see a gain. Tomorrow I'm changing the auxilery drivebelt too, it has been squealing and I'm thinking the friction from that is why I'm getting crap MPG at the mo.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 07-26-2009, 12:27 PM   #4 (permalink)
I have attached a photo of the wiper shield in place (although not angled properly yet).
@IsaacCarlson Well done for getting your wipers out the way, I guess lots of folk could do the same if their cars allowed.
Old 07-26-2009, 12:42 PM   #5 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Good idea. I want to do this on my van but it's not as easy as your seat up.
You might want to have your battery checked and check for a voltage leak at the same time. A dying battery can rob FE by pulling a lot of amps from the engine as it tries to charge it up. A leak drains the battery which the car has to charge up later.
Does it happen when you first start the car and then get better as it warms up? This happened to me. It was the impetus for getting a deep cycle batt and removing the alt altogether.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 07-26-2009, 01:37 PM   #6 (permalink)
...beats walking...
...just make sure the end nearest the windshield "clears" the windshield when you open the hood...alternatively, just make the airdam out of flexable material.
Old 07-26-2009, 02:56 PM   #7 (permalink)
Good tip @Old Tele man, I would second this as I have made mine so that the bonnet clears the end. On this model of Golf it opens at the "nose end". If you have a bonnet with the hinges at the nose end (like a BMW 3 or 5 series) you can get away with just mounting it under the lip.
@orange4boy I have checked my batt, and all is fine, when I came to unbolt the alternator I found it was loose on its mountings and relying on the stock VW spring underneath to tension the belt. I prob could've gotten away with just tightening the belt, but had a new one already. It is amazing the difference it makes, I could feel the engine "wobbling" under acceleration, as if it had a loose engine mount. It must have been the friction from the belt slipping taking its toll on the 75 whole horses this thing makes.
Old 07-26-2009, 08:55 PM   #8 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Lund used to make a product that did this for Ford pickup. Ford wipers accumulate bug guts and snow.
I've only seen a couple of them. Even I think they look dorky.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 07-26-2009, 10:29 PM   #9 (permalink)
I've thought of a disadvantage of a wiper cover. The HVAC intake vents are deprived for their supply of high pressure air.
Old 07-27-2009, 03:16 PM   #10 (permalink)
Forgive me for asking, what is a HVAC intake vent? and why does it need high pressure air?
golf mk3, wiper sheild
Wiper cover test groar Aerodynamics 30 12-14-2019 10:35 PM
Single front wiper crx? chipX Aerodynamics 28 12-05-2009 03:57 PM
Windshield Wiper Cowl / Cover / Blocker Thingy? Sean T. Aerodynamics 42 04-02-2009 02:56 AM
groar's 2001 Scenic Modding Thread groar EcoModding Central 4 11-25-2008 08:22 AM
Wiper area cover? wagonman76 Aerodynamics 3 06-28-2008 01:12 AM
