Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-23-2014, 02:51 AM   #21 (permalink)
Send a message via MSN to markweatherill
Rain is one thing but why not hook up a turbine to your house water supply? Everyone uses some water; mains pressure can be quite high.
Old 07-23-2014, 09:42 AM   #22 (permalink)
I guess it is the expense of adding a turbine to your mains supply for very little gain. Running a tap in the house to fill a kettle would produce "next to nothing"
What I am imagining is Dinorwig on a much smaller scale ( electricmountain dot co dot uk ) ... buffering the water and letting it flow with enough force to produce a reasonable amount of power albeit for a 'short' time /not constant
Old 07-23-2014, 06:14 PM   #23 (permalink)
90 day: 29.78 mpg (US)
Originally Posted by WildBoar View Post
This is something I am also very interested in.
We have constant trickle of spring water on the hillside where we live. (low volume) but we have 50m of head to get the pressure up.
What is your flow rate? 50m of head is good, but the flow has to be there.
My parents have an underground stream that flows 4gpm with a 25ft head, which is useless. They also have a creek with perhaps 400gpm flow and 1ft of head; equally useless. A solar charger is better, cheaper, and less complex.
Pico hydro power doesn't make any sense.
Old 09-03-2014, 01:22 PM   #24 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Interesting topic. It may not be useful to most, but as the Wikipedia page says, if you have the water flow it can help offset solar in the winter. It might also depend on how much power you actually use. For instance, my living room/dining room overhead light is a 2W LED, putting out a 25W incan equivalent. It's enough to eat, talk and play board games. I imagine if someone had a very sparse living situation in a cabin or similar they could power a good amount of their daily electricity use with pico hydro. If a couple lights and a phone charge are all you really need, and you have the water flow, why not?
Use Washing machine to power toilet and save water! bennelson Saving@Home 34 04-02-2010 11:13 PM
Rain water pattern on rear glass QuickLTD Aerodynamics 3 09-04-2009 04:58 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
turbine engine for a geo metro kane66 EcoModding Central 41 10-26-2008 05:39 PM
