Old 10-19-2015, 06:35 PM   #1 (permalink)
random aero factoid
The 1924 Rumpler Sedan,without it's wheels,has the exact,same coefficient of aerodynamic drag as the 1938 AVA G'o'ttingen Schl'o'rwagen
Cd 0.186.
The Following 4 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (11-12-2015), bespurcell (11-15-2015), Cd (11-11-2015), MobilOne (11-13-2015)
Old 10-20-2015, 12:06 AM   #2 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
The schlor's steeper departure vs the rumpler's more template-like slope.
One seems better and pretty, but show me the money!
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
aerohead (10-20-2015)
Old 11-11-2015, 05:38 PM   #3 (permalink)
No wheels?
Is it a hovercraft now?
Old 11-11-2015, 05:45 PM   #4 (permalink)
90 day: 56.53 mpg (US)
No wheels?
A jedi flamingo?
The aerodynamic force is strong with this one...
ksa8907 (11-11-2015)
Old 11-11-2015, 07:36 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for posting that AeroHead.
I like the Rumpler as a good example of what you can do with an upright windshield.
With a plan taper, you can still get a good Cd.
I was thinking the other day of how that a Hummer could be redesigned to appear recognizable as a Hummer with its' trademark upright windshield, yet have excellent aerodynamics.
I did a sketch of what I had in mind and despite having a recognizable form, I think it could still be quite aerodynamic.
Phil, you are quite a good artist. If you feel up to it, would you consider sketching out a design like that yourself ?
Old 11-11-2015, 10:15 PM   #6 (permalink)
I wonder how they compare in crosswind performance, as well as lift.
Old 11-12-2015, 03:19 PM   #7 (permalink)
Unless the body proportion is twice as wide as it is tall, a vertical trailing edge is the natural result. Minimizing or eliminating the taper in elevation reclaims interior volume.
http://www.bgwspectre.com/customer1.html
Hummer isn't the only flat-windshield body.
Old 11-12-2015, 03:56 PM   #8 (permalink)
Most of the van conversions that rely on Type II sheet metal are too wide in the back. This fiberglass clip has, as I calculate, a perfect extension of the body contour. It could be further optimized—fender skirts ... hitch mounted perforated base plate ... plasma trip strips ....
The guy that runs BGW knows that it gets better gas mileage but he doesn't know how much. aerohead, what would your calibrated eyeball say is the Cd? About 0.30? That would translate to 5% gas mileage.
Replace the stock hatch (which really restricts engine access, needs an electric conversion) with V-shaped side-hinged double doors. And the air intake vents with an intake in a V-shaped ducktail spoiler. Boom, instant full boat tail — [Edit:0.25].
Old 11-14-2015, 02:31 PM   #9 (permalink)
1921 Rumpler
Here is the 1921 Rumpler open sedan,Cd 0.54.While adding frontal area,the addition of the 1924 roof nearly cuts the Cd in half.
The car is definitely airfoil-shaped in plan-view.And the panoramic tug-boat windshield with generous header radius, makes for nice penetration without separation.
Old 11-14-2015, 02:48 PM   #10 (permalink)
Hummer h-1
Seems like the Cd 0.70 H-1 could easily go to Cd 0.35 with edge rounding,gap closures and subtle shape optimization.Especially the military 'fastback' version.
I've streamlined them in my mind,but a rendering I've never done,and my plates pretty full for the next year ahead.
The Chevy Colorado was around Cd 0.40 and shared the same chassis as the Cd 0.51 HUMMER H-3,so we know there's some fruit hanging on those HUMMER trees.
But (horrible English!) the demographic who's purchased a Hummer probably would consider a streamlined version of any kind,an abomination and recoil in horror from it as bad as the men folk of 'The Simpson's' Springfield,when a Prius came down Main Street,and guys dove into the bushes to shield themselves from what would certainly rob their manhood if they were to look at it directly.
