Old 07-24-2015, 05:38 AM   #1 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
Ram air intakes
Do they really make that big of a difference? and how do i keep water from going into the air box? my car does not have a drain on the actual pipe but might have on the air box this pic shows the exact layout of my engine. i want to remove the side scoop (bottom rightish) and make my own one to catch more air but im concerned that more rain will go through the airbox as it is approaching our wet and rainy season here now. Click image for larger version
Old 07-24-2015, 05:41 AM   #2 (permalink)
Search function Eddie. Use it. Love it.
Xist (07-24-2015)
Old 07-24-2015, 04:51 PM   #3 (permalink)
Cold air intakes usually are used to increase power or for when the engine has an overheating problem.
For economy's sake, the warmer engine compartment air can be advantageous for the intake system, and partial grill blocking is sometimes done to increase aerodynamics and utilize the advantages of the warm inside air.
So, whether cold air intakes are beneficial depends on what you're trying to achieve.
Old 07-24-2015, 11:16 PM   #4 (permalink)
...beats walking...
As a "general" rule, most Ram-Air intakes only begin "working" at speeds above 100 mph and MPG typically is a secondary objective.
The Following User Says Thank You to gone-ot For This Useful Post:
mcrews (07-25-2015)
Old 07-24-2015, 11:55 PM   #5 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
You may find this helpful.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 07-25-2015, 12:57 AM   #6 (permalink)
If its for a diesel then yes it will help both power and fuel economy.
