Old 01-23-2019, 09:26 PM   #21 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
I tried this in the CRX and could not discern any improvement to mpg.
Also,I put a number of baby jars filled with various viscosity standard and synthetics into the freezer,and next day,did a simultaneous side-by-side tip-test,flow comparison,and the standard Valvoline 10-40W flowed just as well as the most expensive full-synthetic.
You may have a better experience.
If only it were as warm as your typical freezer here.
A few days ago I did an oil change and the Mobile One 0w20 I like to use had the consistency of honey at normal room temperature.
aerohead (01-30-2019)
Old 01-30-2019, 12:03 PM   #22 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
How would this work in a manual? AMSOIL Synthetic Chaincase & Gear Oil. It is used in snowmobiles.
The Following User Says Thank You to diesel_john For This Useful Post:
Old 01-30-2019, 06:05 PM   #23 (permalink)
how would
The manual trans. will have an API GL rating for the proper lube.If the AMSOIL meets or exceeds that spec. then you're good to go.
Google: API Gear Specifications for more detailed info
