Old 04-26-2012, 07:47 PM   #1 (permalink)
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.52 mpg (US)
Starship Resurrected - '08 Toyota Prius
90 day: 45.86 mpg (US)
Relationship between MPG increase and drag decrease?
Has anyone run across a formula or rule of thumb that correlates increases in MPG to drag decrease? Yes, there are a lot of other factors that combine to generate drag, but is there even a rough rule of thumb?
Old 04-26-2012, 08:00 PM   #2 (permalink)
the mpg calculator on this site is the granddaddy of all.
Old 04-26-2012, 08:07 PM   #3 (permalink)
aerohead has posted many a time about a rule of thumb for fe increase/drag decrease. But I don't remember it just now. :/
Old 04-27-2012, 05:57 AM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
~2/3 for highway.
Old 04-27-2012, 01:19 PM   #5 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
MPG % increase is half of aero % increase.
The Following User Says Thank You to Sven7 For This Useful Post:
aerohead (04-27-2012)
Old 04-27-2012, 01:46 PM   #6 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
And it's nice to explain in more detail why this is....
I have done numerous coast down tests with the Insight and Crr and Cd are about equal at 35 mph or so.
This means if you change the aero of your car and make it 100% more slippery to the wind, it will gain you 50% more gas savings, because while the aero part improved 100%, the Crr part stayed the same. Then when you add the new Cd and the old Crr, you have a 50% net gain.
Jim.
Old 04-27-2012, 06:19 PM   #7 (permalink)
Caveat
I just wanted to say that the 50% rule applies at 55 mph.
At 70 mph,a 10% drag reduction will net a 6% mpg improvement.
If you're driving in Wyoming or the Trans-Pecos region of Texas,at 80 mph,it will be even more.
Sven7 (04-27-2012)
Old 04-27-2012, 06:21 PM   #8 (permalink)
Jim.
Aero drag completely eclipses rolling resistance at higher speeds though. The reason is because the lower the load on your engine (generally, in the bottom 50-80% of torque output depending on forced induction or cams and stuff), the less efficiently it runs.
Old 04-27-2012, 06:31 PM   #9 (permalink)
Sven7's Avatar
Jim.
Thanks, I didn't know how the rest broke down because honestly I can't do a lot to change it. Now, aero, that's something to easily improve upon
