If you visit the insightcentral site you can see testing of chinese ebay batteries as well as others. You really get what you pay for. Just think of it as your engine needs rebuilding or replacing.
If you are just going to sell the car, go cheap so the ima light wont be on for a while.
Anyhoo, you can by pass the ima system and drive gas only and save up for the battery. You can also balance it, do the battery stick hokey pokey to get a set in a ball park of similar voltages.
I think you are in VA? You ought to look up JimE on here.
