Old 06-26-2014, 04:08 PM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
'89 Cherokee boggs down/dies when turning left?
My little brother found a good deal on a Grand Jeep Cherokee. When the vehicle gets turned left, it either boggs down or dies. Anyone know what the problem might be? My little brother told me to ask 'all your crazy gas saving friends and that one mechanic you know' (referring to Old Mechanic haha). Any help would be appreciated.
Old 06-26-2014, 04:49 PM   #2 (permalink)
Check the turn signal fluid...
Old 06-26-2014, 05:07 PM   #3 (permalink)
dlb
is it carb'd or fuel injected? if it's carb'd, i would check the fuel level in the float bowl. a low level can cause fuel starvation on corners due to insufficient fuel coverage of the jets.
only other thing i can think of is a problem in the power steering pump. maybe the valves that are supposed to open when turning left are stuck closed, causing the pump to bind, which creates resistance for the crank pulley. might be a long shot, not sure. if the power steering pump is run off its own belt, it would be easy to test though since all you would have to do is remove the belt and go for a drive.
Old 06-26-2014, 05:16 PM   #4 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Check the engine to battery ground - it or may be loose or have a bad connection.
Save gas
Old 06-26-2014, 05:59 PM   #5 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
True story:
My next door neighbor in St Pete had an old crappy old baby blue early 60's sedan she named "Aldo". She named all her cars Italian names, but Aldo was special, because Aldo was not an ambi-turner. Aldo didn't like to turn left for some reason, so every time she drove it, she mapped out a route where she would only have to make right turns.
She owned that car for over two years, and never turned left, not one time!
I would badge the Cherokee an Italian name, and start mapping your routes!
Old 06-26-2014, 06:12 PM   #6 (permalink)
Ok. Serious question.
Does the engine die when its in park and turning left or just when going down the road or both ?
Old 06-26-2014, 06:12 PM   #7 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Prob the strainer on the end of the tank pickup (fell of or clogged). Fill it up to at least 1/2 full and see i it still does it.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 06-26-2014, 06:32 PM   #8 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
You mean just Cherokee, right? Grand Cherokee didn't come out til a few years later.
According to Wikipedia, it should be fuel injected. Which engine is it?
Camry Thread
E-Bike Thread
Old 06-26-2014, 09:29 PM   #9 (permalink)
Furry Furfag
Hi guys, I'm at work so sorry for the late reply. Anyway I don't know much about the Jeep, I know it's fuel injected, other then that idk. I'll call me bro when I get a chance and ask him.
Old 06-26-2014, 09:40 PM   #10 (permalink)
Furry Furfag
Ok I called him, he said that at after idling for about 5 minutes it bogs down on its own then recovers, and he doesn't know about sitting idle and turning left. He said it runs good as long as you don't turn left. He is gonna use it for off-road in so yea, he needs to be able to turn left lol.
Edit. It does not bog down when idling and you turn the wheel left
