Old 07-05-2012, 09:17 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Rerouting exhaust and belly pan idea
What about moving the tail pipe to the middle and above the rear bumper so the exhaust is filling the low pressure area behind the rear of the vehicle? It would also increase exhaust flow
For the belly pan, what if it was sealed all around, then the front would be ducted to just below the windshield, and open to the rear just above the bumper. this would allow the high pressure area under the windshield to push air into the low pressure air behind the car.
Best idea ever, I know! Ad of course, add a k&n air filter
Old 07-05-2012, 09:33 PM   #2 (permalink)
Are you on crack?
The K&N was just the icing on the cake.
Old 07-05-2012, 09:56 PM   #3 (permalink)
Gen II Prianista
Rokeby's Avatar
Frank,
Tells us how you really feel.
(Moments like this soar above the 100+ posts a day about the
mundane matters of aerodynamics, MPG, and fuel efficiency
that I feel compelled to slog through eah day.)
Old 07-05-2012, 11:01 PM   #4 (permalink)
Someone's been watching too much F1. Unless you're driving a screaming formula car or are revving the engine hard enough to sound like one, the exhaust flow isn't that energetic.
Besides... most cars already have the pipe pointing straight into the low pressure area in the vehicle's wake, anyway.
Old 07-06-2012, 12:09 AM   #5 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I got it, and I figured it kinda makes sense! except I doubt there is enough flow to make much of an impact. Maybe with a boat tail like I have outlined in the attached picture, It may make a small difference.
Please take a look and maybe you'll understand what he meant. Again, i doubt there would be any measurable difference. plus it would be offset by the weight of the added pipe. The blue is the exhaust pipe forcing the gases to exit right in the wake
K&N air filter though?
Old 07-06-2012, 04:02 AM   #6 (permalink)
Yeah... but don't most exhausts open out in that area, anyway?
I think what he wanted to do was have the exhaust exit where the license plate or badge exits on a regular car, into the low pressure wake behind the car... which I don't think is much different from simply spewing it out behind the bumper.
K&N... supposedly K&Ns increase fuel economy... supposedly.
Old 07-06-2012, 05:02 AM   #7 (permalink)
Send a message via MSN to markweatherill
A K&N filter on the exhaust would be something to see.
Old 07-06-2012, 09:51 AM   #8 (permalink)
Now there is an idea, maybe I will help clean the exhaust for cleaner emissions
Old 07-06-2012, 09:56 AM   #9 (permalink)
Doesn't every little bit help? Is that not why you guys delete mirrors and duct tape grilles?
Old 07-06-2012, 10:00 AM   #10 (permalink)
I'm sure nobody here is really aware of if it'll make a noticable difference or not. If you think it really will I suggest testing it and sharing your info.
