Old 07-29-2023, 11:04 PM   #1 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Resurrecting a '91 Swift
Fifteen years ago I bought a '91 Chevrolet Sprint, a re-badged Suzuki with the 1 litre 3- cylinder and 5 speed manual. I've been trying to buy a US-only XFI cam for it ever since, to install when I did the rings and valves it needs. Now, I just want to get it going, and wanted to check for age deterioration before driving it up on the ramps to do the engine. Sadly, I couldn't even get the fuel pump to run to change the old fuel.
Inside the tank, one wire has corroded right off, and there is a great deal of rust. A friend who has worked on many Swifts recommends a whole new tank and pump. The pump is currently out of stock at AutoPartsWay.ca and they don't list a tank. I'm working on a Coupe, and don't know if the four-door tank is the same. This climate does not usually cause a lot of rust, but now I wonder what the odds are of finding a good one used, if they have not already been crushed.
I live in northern Saskatchewan, Canada, and don't have a running vehicle now. Any advice would be appreciated.
Old 07-29-2023, 11:23 PM   #2 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
They were sold here as a Geo Metro, I had several many years ago. There was also a Geometroforum.com, I don’t know if that exists any more. I bought a reground xfi cam and a plus 10 cam gear to simulate a real xfi. 3tech was the cam grinder somewhere in Ontario. I found them all through this forum back in 08.
Good luck
Andy
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 07-29-2023, 11:27 PM   #3 (permalink)
Reach out to Metrompg
Old 07-29-2023, 11:36 PM   #4 (permalink)
Geometroforum.com is still there also.
Old 07-30-2023, 02:00 AM   #5 (permalink)
https://www.eastwood.com › por-15-fuel-tank-repair-kit.html
POR-15 Fuel Tank Repair Kit - Eastwood Auto
12 Mar 2023Home Auto Paints & Equip Gas Tank POR-15 Fuel Tank Repair Kit Item # 13431ZP BRAND: POR-15 POR-15 Fuel Tank Repair Kit 4-step kit cleans, prepares and seals your vehicle's gas tank 4.3 (25) Write a review $ 105.22 Buy in monthly payments with Affirm on orders over $50. Learn more In Stock
I got this kit for a Superbeetle gas tank but I haven't usd it yet. Apparently the key to success is to thoroughly clean the rust. Hang it by a rope from a rafter and partial fill it with some abrasive (sand or metal scraps) and shake or vibrate it.
Old 07-30-2023, 01:36 PM   #6 (permalink)
90 day: 51.82 mpg (US)
Bob - I've also found that Metro/Firefly/Swift parts are getting harder to find, at least in Canada. I couldn't get exhaust parts last time I tried. (Ended up getting out the welder and cobbling something together.)
That said, I think you can still get everything from the States, online. For a price of course -- shipping is the issue. Makes it sometimes very expensive to buy economy car parts.
I lucked out... bought a complete running parts car for my '98 a couple of summers ago. I jumped at the chance - these cars are extremely rare around here. ( I saw one on the road when I visited Florida this spring, but I haven't seen one on the road in Ontario for many years.)
And that's the final generation car, not the even older one you have.
Old 07-30-2023, 01:56 PM   #7 (permalink)
You guys are scaring me.
I can no longer get parts for my Superbeetle delivered to my carport, but then it's two decades older that the 1990 Canadian Chevy.
Old 07-30-2023, 04:25 PM   #8 (permalink)
Thanks for all the replies. I had an XFI cam lined up for the third time last winter, but the US owner just didn't want to deal with foreign shipping nohow. 3-tech stopped replying years ago. I'll keep you posted. Since first buying a car around 1998, I've averaged less than $200 pa in parts and depreciation. Those were the days, I guess.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
freebeard (07-30-2023)
Old 07-30-2023, 05:01 PM   #9 (permalink)
I've gotten a thousand dollar car with two hundred in tires, but now the alignment shop is asking US$310 for an inner tie rod end and re-align.
And I find out the DMV thinks it's registered to the previous owner (sadly RIP).
Old 07-30-2023, 09:38 PM   #10 (permalink)
I replaced the front crossmember on a Toyota and then couldn't get an appointment for alignment before a booked trip. I just set up with some blocks and straight edges to measure the toe in, and it was fine. Adjustment would not be hard from there if needed.
