Retaining heat use during EOC
1 Attachment(s)
I'm not sure about the rest of you, but around here it has sure cooled off quickly. Just last week I was going to work and it was 60F out at 7 in the morning. Today it was 34F. So, I was using my heat today. And of course with P&G you kind of loose nice warm heat after a few seconds of EOC. A few more seconds later and its not real warm at all. A bit longer and you may find yourself turning down the fan speed so it doesn't blow cold air on you. Of course, as soon as you bump start, you're jacking the fan speed back up to get the heat back! This is obnoxious to me, so I would like to fix it. Its also a detriment to defrosting when you first start driving. This causes me to run my engine more just so I can stay safe and see.
My first thought thus far is to put in a small 12V coolant pump that runs when the engine is not running. It can be put directly on the 5/8" heater core hose. There seem to be more and more small coolant pumps available as more and more hybrid and start/stop systems are put in place. You can pick one of these up for about $36 on amazon. 12V coolant pump https://ecomodder.com/forum/attachme...1&d=1571146371 I'm very open to other ideas for retaining heat use with the engine off, but this seems to be the simplest I can think of. The next step would be how to turn it on only when the engine is not running. I don't really have any thoughts on that so far, so I would love to hear you guy's thoughts on how we could do this. |
On the ranger, I built a pumped tank system and use a 12v 50 amp solar panel dump heating element, but it is my primary heat /defrost source. You only need pumped storage because you can expand your coolant system. You could use a car coffee heater or two to keep your tank warm. Add a high temp thermostat and waller you're golden
Otoh, isn't being warm anti efficiency? |
Hate to be that guy, but: How much is the fuel savings difference between engine off coasting and engine on coasting(maybe dfco)?
Interesting idea, still. |
My first steps would be engine coolant heater so I start off in the morning with reasonably warm fluid, and a grill block. I tend to run the fan on the lowest setting unless I'm trying to defrost/clear a window because I don't like the extra noise, and it's just about as effective at warming the cabin (hotter air rather than more warm air). Then I have seat heaters which are quite effective and very economical to run.
Interesting idea with the 12v pump though. |
I was gonna go with what will this save, but it's DAOX so I figured that was unnecessary.
Another thought along redpoints line: oil filled room heater before driving. Heavier coat while driving. After all, they DIDN'T have car heaters in 1908. |
When I drove school bus many of them had electric recirculating pumps. The best method was to shut off the engine and turn on the recirculating pump, as it only pumped from the engine to the heater cores. The radiator cooled off very quickly and the thermostat closed, but the hot engine would heat the cab for an hour or more. The running engine kept coolant going to the radiator and would actually cool it off faster, circa 15 minutes for an idling bus engine.
Sorry for the incomplete thought: the point was that your idea should work fine, though I imagine you couldn't sit and use it long term, but for 10-15 minutes it would probably stay warm, and certainly enough to take care of EOC. as for wiring, if you have a toggle kill switch, you could maybe figure a way to have the toggle disconnect your fuel injectors, and at the same time cut power to a normally closed relay that runs this little pump. Of course the pump power would have to also run through ignition, or else be manually toggled off when you shut the car off or drain the battery dead.
As for the circulation pump itself, you could buy it second hand even cheaper from a junk yard. Some cars have a pump like that, for circulating coolant after shutdown, if necessary for cooling. Fans also run during this time. I believe vw t4 vans have this feature? Correct me if i'm wrong. |
Great idea again Daox! I see some pre trip heaters might be good for cold mornings. Ever see one like this? Kat's 13150 1500 Watt Aluminum Circulating Tank Heater
