Old 08-22-2014, 07:31 AM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Gas sipping generators?
An interesting idea my mom and I were throwing back and forth, are there any generators capable of running a small heater for 4-6 hours that would use less than a gallon of gas? One of the posts I work up here I have no access to electricity and it gets ~20F at night. If I could burn 1/2-3/4 gallon a day, it would be worth it to me personally to he comfortable. Unless there is some sort of plug-inable thing that is capable of the same feat, I think it's my best option.
P.S to clarify, the genny would only be running about 6 hours a night max. Maybe 8 if it got really cold and I had to have it running all shift. She asked if a car battery is capable since we have a trickle charger at home, but I don't think it is.
Old 08-22-2014, 07:43 AM   #2 (permalink)
Combust the fuel, get heat. Cut out the middleman.
Old 08-22-2014, 09:37 AM   #3 (permalink)
Furry Furfag
Ha, ha ha. Ha ha ha.
Anyway, I was looking at this one but idk. It seems small enough and strong enough, and I can't find anything else around that price.
900 Peak/800 Running Watts, 2 HP (63cc) Gas Generator
The Following User Says Thank You to Baltothewolf For This Useful Post:
Cobb (08-22-2014)
Old 08-22-2014, 09:43 AM   #4 (permalink)
Electric vest powered from 12v battery. Make it yourself for $10. Takes a lot less energy if you put the heat right into the body not air. 20-30 watt should be plenty, but if your going to do it, wire 2 circuits so you can have 3 heat settings.
Made one about 10 years ago for winter motorcycle commute.
http://www.yamahafz1oa.com/forum/sho...d.php?p=922173
Using a battery you'll only get 12 volts, so have to adjust calculation for that.
Old 08-22-2014, 09:44 AM   #5 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Waste oil heater or wood burner if you have a ready supply of either.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 08-22-2014, 09:53 AM   #6 (permalink)
I was serious. Use a fueled heater of some sort.
Old 08-22-2014, 09:56 AM   #7 (permalink)
Furry Furfag
I'm sitting inside of a car. It has to not kill me with fumes :P. The reason I thought of a generator was I could run a extension cord through a small cracked window.
Old 08-22-2014, 09:58 AM   #8 (permalink)
They wouldn't in a house, but you never said car. Look at apu's, its what they're designed for.
Old 08-22-2014, 10:03 AM   #9 (permalink)
Furry Furfag
What is an apu exactly?
Old 08-22-2014, 12:04 PM   #10 (permalink)
Auxillary Power unit, big trucks use it instead of idling.
If all you need is heat, look towards RV stuff. My old VW camper had a gas feed heater. Which would be more efficient like Frank said.
