02-14-2016, 04:49 AM
Oh great! Where does this cable go?
No CELs!
Thank you very much!
02-14-2016, 07:27 AM
That thing in your hand is a cable? Most common loose cable end I saw in Hondas was engine to chassis ground.
regards
mech
02-14-2016, 07:43 AM
Rat Racer
Maybe that car had its appendix removed by a previous owner?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
02-14-2016, 11:42 AM
Cruise control?
02-14-2016, 11:43 AM
Furry Furfag
That would be a loose plug, not cable.
Anyway, brake light sensor? Only thing in that area I could think of.
KSA, Honda civic HX doesn't come with cruise control sadly.
02-14-2016, 12:07 PM
That looks to me like it belongs to the IACV, though that's a shared plug-end with a lot of other sensors.
You can be sure its mate is within reach of the cable, at least.
02-15-2016, 08:38 PM
Reverse light switch from the transmission?
02-15-2016, 10:54 PM
Ah nuts. I found pictures of the brake light and IACV connectors, as well as a zoomed-in picture of the loose appendix, but apparently I did it wrong or something.
It does not look like the picture of the reverse light switch that I found. I had planned on looking closer today, getting under the car, etc., but I was not able to work on it today.
Thank you very much for your ideas!
02-16-2016, 12:43 PM
#9 (permalink)
A wild parasite appeared!
Thanks everybody!
02-16-2016, 08:58 PM
#10 (permalink)
It's a lockdown for the crank pulley?  Hahaha!
