Old 01-14-2013, 03:01 AM   #1 (permalink)
Rolling resistance video
Some of you might enjoy this. The RR parts starts at 24:40 if youtube doesn't take you there automatically. Enjoy.
http://www.youtube.com/watch?feature...FQ_414#t=1484s
The Following User Says Thank You to tjts1 For This Useful Post:
MetroMPG (01-14-2013)
Old 01-14-2013, 04:16 AM   #2 (permalink)
kah
The Mii - '12 Seat Mii Reference
90 day: 54.83 mpg (US)
At 35.05 min. they talk about tirepressure, might be very interesting for all those ecomodders running overinflated tyres!
Old 01-14-2013, 04:48 AM   #3 (permalink)
That's pretty standard knowledge. Overinflated tires incur a penalty in terms of longitudinal traction, but they're often better in terms of wet grip and cornering. If you want the best braking, underinflate your tires.
Also note: ABS. A rigid tire will "bounce" and trigger the ABS system more. If you adjust the suspension to make up for the bounce, you can shorten that braking distance.
Too bad they didn't specify what pressures were used in that test. Hmmm... sounds like something we can test on track next month.
Love the drifting truck sequence afterwards...
Old 01-14-2013, 07:13 PM   #4 (permalink)
90 day: 57.73 mpg (US)
Bugs me when they say things like "rolling restistance is the friction of the tires against the road."
Good find, though. Thanks for posting.
Old 01-15-2013, 10:42 AM   #5 (permalink)
Where did you find the information on over inflated tires are better in wet grip and cornering?
With my Wrangler I average 40 mpg. Triumph Speedmaster 60 mpg + Jeep 20 mpg = 40 mpg!
Old 01-15-2013, 09:27 PM   #6 (permalink)
The narrower a tire's footprint, the better it resists hydroplaning, though I suppose that not all tires will lift off the road in the same way, and it depends on what your door sticker pressures are. Lots of new cars require higher pressures than before, but there are still benefits. Of course, when I say overinflation, I mean inflating to the maximum sidewall pressure, which is usually higher than door sticker.
As for cornering, maybe I should retract that. Higher inflation doesn't increase grip, but it improves response. Definitely a must for taller tires on the track, as they roll over dangerously onto the sidewalls at stock inflation pressures and change direction sluggishly through switchbacks. Many performance tires are perfectly fine at regular pressures, though. stiffer sidewalls.
Old 01-15-2013, 09:34 PM   #7 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
- Tony
Old 01-18-2013, 01:24 PM   #8 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
Not much on rolling resistance but a great video nonetheless! Thanks for posting it!
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
