Old 02-20-2013, 02:27 PM   #1 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
roof cargo box rearward facing?
Hi,
every time I see someone with roof box I wonder: wouldn't be better from aero point of view to mount them rearward? They usually have pointy front, but blunt back... example here.
Did anybody coast down test? Only info I have found so far is in this post http://ecomodder.com/forum/showthrea...enalty-96.html
Old 02-20-2013, 03:16 PM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Interesting idea... I have a cargo box (but no roof rack for now ) so maybe I'll make some tests someday.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-20-2013, 03:21 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I have thought the same thing. Haven't tried a coast-down yet. I use it for skis and snowboards in the winter only. Perhaps I will try it before I hang it up for the summer.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 02-20-2013, 06:15 PM   #4 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Build a blunt fiberglass "front" onto it and you'll be good to go. Probably not that much difference, though. 5%?
Old 02-20-2013, 06:31 PM   #5 (permalink)
facing/stability
I don't 'know' anything about these cargo carriers.
As an independent entity,they are aerodynamically 'backwards' as far as 'ideal' drag goes,so you make the leap,that they should be reverse-mounted.
The only caveat that I can think of,is that during wind tunnel testing,with yaw introduced to simulate some crosswind,that they went with the rearward center of pressure of the blunt rear as a concession to straight-line stability.
My opinion is to never use any of them,using a receiver-hitch mounted cargo carrier instead.Preferably boat-tailed.
Old 02-21-2013, 01:13 AM   #6 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Try these:
Which way would you install skibox
Most aerodynamic cargo box?
