Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 09-10-2011, 04:09 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
New fuel saving coolant up to 15% savings :d
Cartential | Facebook
I cannot figure out what that could do the engine to make it run with less fuel .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-10-2011, 04:49 AM   #2 (permalink)
This **** and the Unicorn Corral were made for each other.
Everyone, you owe it to yourselves to go to the "wall" and read the "2 new photos to the album About Cartential" from July 3- it contains a "whole... nubber... lebbel..." of Bullisht that even politicians rarely attain. Even Doug Palmear and Lois LaPointe would be impressed and humbled. Thanks for the ROFLMAO moment!
They do have the sense to call it a "product novelty from Asia".
Old 09-10-2011, 05:00 AM   #3 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
How about this then?
Fitch Fuel Catalyst - Home
They claim that they have proven test documents to show at Linkedin where I founded these two...
Old 09-10-2011, 05:48 AM   #4 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It's truly magic stuff :
How does Cartential® work?
The product is added to the cooling system of the engine.
But it works on the fuel
Through the ionic effect of Cartential® the molecular chains of the fuel are broken down into smaller pieces.
So might work, however briefly, if you have a leaking head gasket
Old 09-10-2011, 06:54 AM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
There are small gains to be made with a coolant with lower heat capacity, due to slightly faster warm up. But this is unicorn milk.
Old 09-10-2011, 02:14 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Yes I know if fluids has better thermal properties there is not so much need to run the fan ect. but I cannot think any other gain that could have big effects on fuel consumption. I think water is best, but it rusts off your system so you have to stuff to make it suitable...
Old 09-10-2011, 03:18 PM   #7 (permalink)
euromodder's Avatar
Water is certainly not the best, it boils too easily.
That's why coolant is added.
Best option is to get rid of the water altogether, and use a propylene-glycol based coolant (Like the Evans NPG coolants). With a higher thermostat, and higher fan on/off temps - I might give that a try on my diesel.
It would improve the oil dilution problems a bit from the other end - hotter cylinder walls, giving a bit less condensation.
Old 09-10-2011, 03:47 PM   #8 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Well, think stuff must work--I see Al Gore liked it on Facebook. If it's good enough for the inventor of the internet, it's good enough for me! I'm sure 99.99% of the world's climate scientists agree that this stuff works too!
My favorite #1: "Through the temperature development and the special ingredients of Cartential® a highly effective plasma field is generated."
My favorite #2:"This causes a reduction of the polluting components CO and CO2 of the emissions by up to 80%" This would mean you're producing only 20% of what you were before (5x less). The only way you can produce 5x less CO2 is to burn 5x less fuel (carbon in = carbon out). Sweet! I need to get me some of this stuff--I'll get 150+ mpg with my pickup! 5,000+ miles on a tank of fuel! I'll only have to fill up 2-3 times a year!
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 09-10-2011, 05:00 PM   #9 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Water also freezes and causes things like cracks in water jackets and what not.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 09-11-2011, 01:46 PM   #10 (permalink)
...beats walking...
...or, unicorn piss?
