Old 07-15-2010, 12:17 PM   #1 (permalink)
16 Ferret Circus
bnmorgan's Avatar
GrumblyDavidson - '00 Harley Davidson Road King FLHRP-I
90 day: 38.37 mpg (US)
Golf - '04 Volkswagen Golf GL-TDI
90 day: 38.29 mpg (US)
New scangauge, odd °fWT
Got my scangauge yesterday, and of course like a kid with a new toy went right to installing and figuring out how to do it.
Car spec first, 2001 Beetle TDI, 1.9L
I'm all good except the MPG, which if i understand has to be tuned or calibrated at fillup, which won't happen for another 1/2 tank or so (only at 300 miles now).
Problem is, my fWT blinks something that i think is overboard, ~205-210 at highway speed, but every few seconds, it will blink just long enough to read about. at crank this morning, it showed 73/80, but they swapped places along the way. My fIA shows ~98-105, which i figure is probably about right for 85-95 ambient temp and 5-10 lb boost.
Suggestions or tips? I did search the forum but didn't come up with anything, but y'all usually know things i don't on where to find things.
Thanks.
the e30 is dead
Old 08-02-2010, 04:20 AM   #2 (permalink)
The PRC.
One immediate thought that occurred reading this was a loose connection in the OBD port but then again it is digital so you would get the right signal or nothing. On my car the port is completely closed when a cubby hole door is shut so I had it going off a couple of times when the plug was nudged out.
So (another theory I'm afraid) could it be a faulty temp sensor on the engine occasionally reading very high ? That would lead to the SG2 'sampling' that value and occasionally displaying it.
You don't get a warning because the ECU is programmed to smooth those things out before reporting a fault. i.e. the ECU designers realised that physical components occasionally go wrong and they compensated for it in software.
You could ignore it or get the sensor changed - start with the cheapest bit.
Old 08-02-2010, 10:06 AM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the scangauge (and most obd solutions) only gauge the airflow and assume the mixture is reasonably close to stoichiometric , the tdi is rarely anywhere near stoichiometric and does not produce useable mpg numbers in this manner.
Old 08-02-2010, 02:11 PM   #4 (permalink)
The PRC.
Don't know how that would affect temp but can I point you at my thread (steady...).
http://ecomodder.com/forum/showthrea...ons-14059.html
I have a few MPG SG2 stylee questions.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Scangauge 2: monitoring hp on an Ion manderson99 Instrumentation 5 06-08-2010 11:05 AM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Mini test: how ScanGauge calculates average speed MetroMPG Instrumentation 7 04-14-2009 10:16 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
