Old 06-05-2010, 06:38 PM   #1 (permalink)
Scangauge 2: monitoring hp on an Ion
It would seem that the Scangauge 2 may or may not support horsepower monitoring depending on the car's sensors. I also don't know if horsepower monitoring is available "out of the box" or if one must pay for a firmware update to get it.
So . . .
1). Can the Scangauge 2 read horsepower off the OBD-II port of an '04 Saturn Ion 1 (auto)?
2). Is this feature included in the base price for a new Scangauge 2?
Please understand that it is primarily my wish to acquire a gauge of some sort to measure changes in fuel economy with and without specific mods to my car, though I would also like to monitor horsepower, even though it is highly probable that the Scangauge 2 only monitors horsepower at the crank rather than at the wheel.
Old 06-05-2010, 08:10 PM   #2 (permalink)
...beats walking...
...NO current engine computers actually determine or calculate engine horsepower, that's a derived value that needs to know engine torque vs. rpm. The only exception I know of is the Bugatti Veyron, but I don't know how they do it.
...most add-on devices simply 'estimate' HP from other inputs, and are almost guaranteed to NOT be accurate...close, sometimes, but almost always somewhat in-accurate 100% of the time.
Last edited by gone-ot; 06-05-2010 at 09:53 PM.. Reason: added reference to Bugatti Veyron.
Old 06-06-2010, 04:06 AM   #3 (permalink)
From what I read, the Scangauge 2 runs about 15-20% over whp. Really I'm not all that concerned with accuracy, I just want to see hp deltas when I make changes to the car. So, as long as it remains consistent in its inaccuracy, I'd be cool with that.
So I guess the questions should be, can it read the necessary inputs off an '04 Saturn Ion 1 to make those horsepower estimates, and will it do that out of the box?
Old 06-06-2010, 09:26 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Yes, HP is a programmable xgauge option available on the Scangauge II. It works on every OBD-II car I've plugged my SG into. As Tele says, it's an estimated value. I know my xB only makes 108 hp, but the SG has displayed over 140 hp, and I wasn't even flooring it.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 06-08-2010, 08:03 AM   #5 (permalink)
Excellent, thank you. I had been looking at a cheaper unit, but it looks like I am going to have to get a Scangauge 2 to measure hp deltas as well. It doesn't look like any of the cheaper models have a similar feature.
Either that or I'll get a Dashhawk for data logging. They're a bit spendy though.
Old 06-08-2010, 11:05 AM   #6 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
What gear were you in when you saw 140 on the SG?
The reason I ask is because I imagine to get any kind of accurate hp rating on the SG, you would have to be WOT in 4th gear on a 5-speed or in 5th gear on a 6-speed since those gears are typically 1:1 ratio and that's how it's done on a dyno.
If I was to take my Cube and put it on a dyno and floor it in 1st gear, I bet it would read close to 300hp even though my little 1.8 only produces a max of 122hp.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
ScanGauge - amazing or..? Spidybot Instrumentation 6 12-09-2009 10:00 AM
Noob scangauge questions vielecustoms Instrumentation 3 10-05-2009 02:12 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
