Old 03-29-2014, 12:21 PM   #1 (permalink)
seafoam for a civic hx?
Hello all I was just curious I wanted to clean up my 98 hx , I just wanted to make sure i was wanting to do either fuel injector cleaner, or seafoam it, does anyone know if I use seafoam if it will hurt anything?
Old 03-29-2014, 12:44 PM   #2 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I've used seafoam on all of my cars for years. Really Old cars and not-so-old cars. They've all been running fine.
I've never ran into the whole "Seafoam will clean out the gunk holding really old car engines together killed my engine"
since your car is pretty old, I suggest using seafoam in a VERY WELL VENTILATED AREA because it will produce A LOT of smoke.
If you do use seafoam, plan on changing out the spark plugs afterwards. Therefore, I've generally used seafom after every 10K miles when I change out the spark plugs anyways.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 03-29-2014, 12:50 PM   #3 (permalink)
I was planning on seafoaming, then next weekend full synthetic oil change , and ill add spark plugs to that list, my car has 196k so I'm hoping it cleans out some old junk, thanks for your reply
Old 03-29-2014, 12:55 PM   #4 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Oh it WILL clean out the gunk
Old 03-29-2014, 01:03 PM   #5 (permalink)
If you feed the sea foam into the intake make sure there is no where for it pool.
Ideally you would feed it into the intake while on the road, preferably at full throttle.
Old 03-29-2014, 01:18 PM   #6 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
...wait ...what? How?
Old 03-29-2014, 04:05 PM   #7 (permalink)
I started having misfires in my HX, so I replaced the spark plugs and wires. That still did not fix the problem, so I poured a can of Seafoam in my gas tank, and after a couple of miles, everything cleared out.
I should have used the Seafoam before replacing my spark plugs and wires?
Then it would have driven fine and I would have left them alone!
Old 03-29-2014, 04:31 PM   #8 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Seafoam has good ratings on amazon.
Amazon.com: Customer Reviews: Sea Foam Motor Tune - Up
Here's a tutorial on how to use it.
http://ls1tech.com/forums/general-ma...-your-car.html
