Old 06-08-2009, 10:19 PM   #11 (permalink)
Originally Posted by stevey_frac View Post
Ooo.. Found the seal in Picture 2. On top of the radiator. Goodness, I need to get glasses.
No, you dont. Or infact, we both probably do.
I spent at least 2 or 3 mins looking at the piccies, then i concluded the OP must of made a mistake and uploaded the same picture twice.
Now you point it out.... lol
Old 06-09-2009, 04:43 PM   #12 (permalink)
That looks like an exhaust manifold heat shield touching the foam. Is it? Seems like a special very high temperature foam would be needed to do that safely. The regular sorts of sealing foams are going to release awful fumes if heated to exhaust temperatures, and they might even go up in flames.
Old 06-09-2009, 05:13 PM   #13 (permalink)
I sure hope most cars exhaust manifolds aren't that close to the radiator! To answer your question, no that is simply part of the frame.
Old 06-09-2009, 05:28 PM   #14 (permalink)
Ah good. The exhaust manifold on my Protege5 is on the front side of the motor near the radiator. However, it isn't as close to the radiator as is the frame in your picture.
Radiator block + EOC vs. heat soak some_other_dave EcoModding Central 6 05-16-2009 02:02 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 08:54 PM
Air sealing!!!! rjacob Saving@Home 5 08-20-2008 09:29 PM
5 min radiator block aeromod bennelson Aerodynamics 20 02-24-2008 11:40 PM
Ecomodding Smaller Radiator of Choice? XFi EcoModding Central 2 01-22-2008 05:53 PM
