Old 02-18-2011, 11:34 PM   #1 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
what mpg meter for 1989 chevy celebrity?
What mpg meter would work with a 1989 chevy celebrity?
I joined the forum due to finding the following link where someone got 35.33 mpg with this model of car.
ecomodder.com/forum/em-fuel-log.php?vehicleid=731
I used to keep track of mileage and only got around 22 mpg, so this is very impressive to me. I pay cash for gas and it would be a hassle to fill the tank every time, but I'd love to get a mpg meter and get the mpg above 30.
Old 02-18-2011, 11:56 PM   #2 (permalink)
Welcome to EM,
I don't think that any vehicles prior to 1996 have the OBD II data plug that you need for an MPG meter?
You can check any threads by the owner of that car:
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - View Profile: wagonman76
...and see what mods they have done and/or how they drive to get the MPG.
Tank by tank MPG is the most accurate way to go, and you can check the calibration of your odometer, too.
j12piprius (02-19-2011)
Old 02-19-2011, 12:19 AM   #3 (permalink)
Liberty Lover
j12piprius's Avatar
Welcome to EM,
Thank you. ... can the OBD II plug be installed or would that be too expensive?
ecomodder.com/forum/member-wagonman76.html
Thank you very much.
Oh? Why is that? I was under the impression that tank to tank was not accurate at all, because the tank fills to a different level each time. When I used to fill and write results meticulously, I'd get 18 one time and 26 another, with the same type of driving. That was one reason that I stopped recording the mileage.
Old 02-19-2011, 12:51 AM   #4 (permalink)
As long as its fuel injected you can use a MPGuino.
http://ecomodder.com/forum/showthrea...able-6914.html
The Following 3 Users Say Thank You to redneck For This Useful Post:
cfg83 (02-26-2011), j12piprius (02-19-2011), vegafan (03-08-2011)
Old 02-19-2011, 12:57 AM   #5 (permalink)
Liberty Lover
j12piprius's Avatar
ecomodder.com/forum/showthread.php/official-mpguino-preassembled-now-available-6914.html
Thanks.
The mpguino looks interesting, but I'm not confident of being able to install it.
Old 02-19-2011, 01:05 AM   #6 (permalink)
There's only four wires.
Positive
Negative
VSS - vehicle speed sensor (speedometer)
Injector signial
It's not hard to install and works great...
Old 02-19-2011, 01:09 AM   #7 (permalink)
Liberty Lover
j12piprius's Avatar
Positive
Negative
Injector signial
Thanks for the encouragement.
Don't you have to put a case on it, and program your car's information?
Does it have instructions on how & where the wires are connected?
Old 02-19-2011, 01:18 AM   #8 (permalink)
This should help answer your questions.
MPGuino - EcoModder
Or, just use a old fashioned vacuum gauge .
The MPGuino is better though.
Old 02-19-2011, 01:23 AM   #9 (permalink)
Liberty Lover
j12piprius's Avatar
ecomodder.com/wiki/index.php/MPGuino]MPGuino - EcoModder
Or, just use a old fashioned vacuum guage.
That's what I'm talking about - very complicated.
I think that's too complicated for me. I'll check the vacuum gauge.
Old 02-19-2011, 11:45 AM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by johnlvs2run View Post
Thanks.
I installed one ( actually mine is a SuperMID ) and I'm a complete idiot.
You are a lot smarter than I am, so it should be no problem.
The Following User Says Thank You to Cd For This Useful Post:
1989 chevy celebrity, mpg meter
