12-17-2015, 11:20 AM
#81 (permalink)
Rat Racer
The faster warmup is more pronounced when it's colder, and the denser winter air means any aero benefit is, too.
I've been loving the faster warmups.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
12-19-2015, 08:52 PM
#82 (permalink)
herp derp Apprentice
W/o flash
W/ flash
Living off the air dam, full grill block, about 7-8yrs old, tape on corners last redone 2-3yrs ago same time as forward air dam added
The Following 2 Users Say Thank You to 2000mc For This Useful Post:
12-20-2015, 01:47 AM
#83 (permalink)
Wannabe hyper..., miler !
Nice to have a plastic car, easy to tinker with ...
Good lower splitter
12-20-2015, 08:27 PM
#84 (permalink)
Not banned yet
getto - '02 Volkswagen Jetta GLS TDI 90 day: 53.82 mpg (US) Blue - '03 Chevy S-10, LS
my version 3, but it might even be 4. losing count.
more info:
http://ecomodder.com/forum/showthrea...iii-33187.html
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, ventectomy, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following 2 Users Say Thank You to deejaaa For This Useful Post:
12-21-2015, 11:22 AM
#85 (permalink)
I finally did a block of my 2013 Passat, but it's nothing I can show you because I put it behind the grille. It's just two pieces of flashing sitting in the frame member behind the bumper. I got the info on how to remove the grille here:
VWVortex.com - How to remove front grill?
It was just too difficult to try to find a cover for the outside that did not look seriously oogly. I understand it is not quite as effective aerodynamically. I suppose I could always tape some plastic on the outside there temporarily, for a long trip.
The bottom grille is just an area where I use some of that almost black gorilla tape, which allows me to adjust the opening size easily.
The Following 2 Users Say Thank You to PaulB2 For This Useful Post:
12-21-2015, 06:48 PM
#86 (permalink)
Yeah, I got one of them VW's and the grille is something to do an interior pasting to.
Installed some of the flat pieces of "cutting" board plastic that are thin and come in all kinds of colors, I had yellow(free), it can't really be seen.
Reason: !
The Following User Says Thank You to bikeprof For This Useful Post:
12-23-2015, 08:01 PM
#87 (permalink)
It turns out there is an aftermarket shield for this car:
2012+ Passat NMS Winter Front - NMSPASSAT - IDParts.com
It's aimed at faster winter heating but probably works for aero too. Might look a bit strange driving the car with this on during the summer though.
The Following User Says Thank You to PaulB2 For This Useful Post:
12-23-2015, 09:10 PM
#88 (permalink)
Looks good, but the traditional appearance winter front, makes me think you'll have concerned citizens trying to let you know you forgot to remove your grill block all summer long
12-23-2015, 10:26 PM
#89 (permalink)
Not banned yet
I drive with mine all year. only jumps to 210 in stop and go.
The Following User Says Thank You to deejaaa For This Useful Post:
12-24-2015, 02:35 AM
#90 (permalink)
I do not know about stop and go with mine, but it would start overheating if I kept up with traffic and\or was going up a hill, but it gets warm here in Arizona.
I still have not fixed my bumper, but I will close the opening that I cut in it. We will see what that does.
