Old 05-07-2012, 09:29 PM   #11 (permalink)
Buggie - '01 Vw Beetle TDI Gls
I don't believe that for a second. Unless there's something special about your engine, we haven't found any econo benefit from shutting injectors off.
Got a scan gauge? Plug it in, disconnect some injectors, go for a drive and post your results
Old 05-07-2012, 09:40 PM   #12 (permalink)
I don't have one. Wouldn't having disabled injectors mess up it's reading?
Again, this hasn't been proven to work.
Old 05-07-2012, 10:53 PM   #13 (permalink)
You personally tested it?
How did you test it? Did you use a scan gauge? What kind of vehicle?
Old 05-07-2012, 11:02 PM   #14 (permalink)
I did try it on a Tempo. I did not find any benefit. Use the search function to see what others have posted.
Old 05-08-2012, 11:49 AM   #15 (permalink)
what year tempo? which engine? did u disable the valves? How did u do that?
did you post your results on this list and your testing methodology?
Old 05-08-2012, 11:52 AM   #16 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
How do you balance this thing? It will shake itself to bits.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 05-08-2012, 02:55 PM   #17 (permalink)
chrisgerman1983 - '96 chevrolet astro
90 day: 14.02 mpg (US)
What is the main problem to doing this... I am asking out of lack of mechanical knowledge .... if it is compression and the pistons not being pushed back up in turn creating drag? Could you have a air tank to really introduce compression? It would take a large tank and would only work for short drives but in theory would it work? Just thinking out loud mostly.... I am also on my phone so searching is not easy
Old 05-08-2012, 02:58 PM   #18 (permalink)
Dont know where "really" came from? Damn autocorrect...
Old 05-08-2012, 02:59 PM   #19 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by mans View Post
"doing it right"
can anyone say exactly HOW to "DO IT RIGHT"?
VW are closing the valves and shutting off the injectors at low load.
