Old 03-19-2011, 12:49 AM   #21 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Had a 250 cubic inch '70 C-10 manual. Getting that '3 on the tree' manual column to shift was hard enough using the clutch. 2nd to 3rd would work without the clutch but 1st to 2nd, forget it. Truck was about as bare bones as they get. Drum brakes, manual shift, no radio, 3 speed on the column, manual windows and door locks.
Don't use the clutch in my 5 spd diesel truck. Use a 2-4 skip shift for upshifts no clutch. Seems to slide in 4th gear easy. For the RX7 it's 1 to 3 without the clutch then to 4th or 5th depending on the speed limit. Still use the clutch with the cycle but it's still new. Need to get a feel for it first.
VT247
Originally Posted by ShadeTreeMech View Post
I've driven every stick shift vehicle I've been in without the clutch, and except for a 67 Chevy C-10, none of them complained.
Old 03-20-2011, 07:13 PM   #22 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
What proof is there that properly shifting without the clutch increases wear on the transmission? I've yet to talk to anyone that said he used to shift without a clutch, but then it wore out his transmission, so he stopped doing it.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 03-21-2011, 01:13 PM   #23 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Its not when you do it properly. Its when you screw up which is bound to happen.
Old 03-21-2011, 01:21 PM   #24 (permalink)
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
Bingo... kinda like doing a DFCO in neutral and losing vacuum on your power brakes, then plowing thru an intersection on a red light. Almost did that a couple times. Next car I DFCO in neutral will be designed for it (no vacuum booster, disabled steering wheel lock mechanism).
IMO, until you've truly foolproofed it, some things are just best not doing since the potential risks are greater than the benefits.
Old 03-21-2011, 03:30 PM   #25 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
I've been wondering why the steering wheel locks. Is that difficult to disable?
Old 03-21-2011, 07:47 PM   #26 (permalink)
Basjoos Wannabe
It's real simple.
Don't turn the key to the locked position.
Between locked and on is a position that keep the wheel unlocked, and only turns off the electrics. So go to that one.
I agree. I'd certainly recommend practicing this on a beater. And I wouldn't recommend this for people who have no interest in mechanics and could care less for where the revs are likely to be close to for a certain gear at a certain speed. But then again, such people are likely to be uninterested in a stick shift to begin with.
Old 03-21-2011, 08:16 PM   #27 (permalink)
the mechanisms are in the steering column and, depending on the car, dictates the level of complication one must go through to disable it.
Old 03-22-2011, 08:20 PM   #28 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I don't use the clutch when upshifting my motorcycles. It is very smooth and faster than using it. I use the clutch for downshifting generally. I have shifted my manual shift cars without the clutch but I think it is generally less smooth.
I would like to have a double clutch manual shift transmission although I have never tried one.
Noah Webster, 1787
Old 04-26-2011, 09:57 PM   #29 (permalink)
Black Beauty - '13 Hyundai Elantra
Learned to slip shift today. Tried to be gentle, little bit of clunking here and there. Fifth seems to be hardest to get into. It was the only gear I ever got any screeching from. As soon as I hear that I back off and use the clutch. It was also the only gear I wasn't able to get into perfectly smooth.
Any tips? Am I more likely having timing problems or do I need to get in just the right spot side-to-side with the shifter or something?
Last edited by justjohn; 04-26-2011 at 10:06 PM.. Reason: Got rid of bump start question after realizing that was from a different thread
Old 04-27-2011, 04:10 PM   #30 (permalink)
Escape #2 - '13 Ford Escape Titanium
C-max - '17 Ford C-Max SE
I asked one of the diesel mechanics here about it -
If you shift properly, there's not one tiny bit of difference using the clutch vs not using the clutch for fuel economy. note this is on big rigs, where to downshift you have to rev the engine up in neutral even when using the clutch - and rolling in neutral is a good way to get yourself killed in a big rig, so that question never came up, although the trucker term for it is Georgia Overdrive or sometimes Mexican overdrive. Gotta be on some serious medication to try that...(in a semi)
he went on to say that while you could make a case that you were causing less wear and tear on the clutch, that one shift you miss will cause 100 times the wear that a lifetime of using the clutch would cause.
I do not know if this part applies to cars - he also gave me a very strong warning against rolling down a hill in gear with the clutch depressed. He told me that due to the multiple reductions involved and no pressure on the clutch, it can actually cause the clutch to explode and send shrapnel through the cab of the truck
I'll admit to being quite guilty of not using the clutch when shifting especially in the low range gears Dont tell anyone. lol
