Old 05-15-2013, 12:08 AM   #31 (permalink)
Originally Posted by nackerton View Post
Has anyone tried LiFeYPOs as a start battery?
EV-Power | WB-LYP40AHA LiFeYPO4 (3.2V/40Ah)
Four of those connected in series and you have a 100 Ah lead acid battery replaced (atleast in terms of cold cranking amps).
Yeah I am one of the few and the only person I know of that has went LiFePO4 on a large V8 high compression diesel.
Old 05-15-2013, 03:11 AM   #32 (permalink)
So how is it working for you? What cells are you using?
Old 05-15-2013, 11:48 AM   #33 (permalink)
Its all here:
DIY: BYOB, for more power, a lot less weight - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old 05-15-2013, 04:07 PM   #34 (permalink)
Nice work. You could check that yttrium chemistry, atleast they make a promise that it would work in winter too. No need to carry the batt with you
Old 06-03-2013, 10:01 AM   #35 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by PaleMelanesian View Post
Honda's ahead of the game on this one. (yay? ) My Fit has a 151R battery, rated at 330 CCA. It's smaller than the Miata battery. Some folks with Fits are "upgrading" to the Miata battery for more capacity. You can definitely take things too far and I think this is one case where they did.
Seriously, the thing is just an inch bigger than those lawn mower batteries.
Correction. I replaced my mower's battery this weekend. It's a 340 CCA unit, MORE than the Fit's.
Old 06-03-2013, 02:45 PM   #36 (permalink)
Originally Posted by 96vtec
you could always carry a small jump starter in the trunk with you.
These don't weigh much. Used pre-delivery with Golf/Jetta/etc., they show up at swap meets.
Put the battery at the center of gravity to reduce polar moment when cornering.
Old 07-19-2013, 09:18 AM   #37 (permalink)
Bruce Wayne
Pleased with the creative ideas. I had given a try for this idea in my car but failed due to using over-charged battery. Later I sorted out the things and made it run.
braille, odyssey, optima
