Old 01-04-2010, 01:01 AM   #11 (permalink)
Originally Posted by dward1 View Post
I'm working on driving habits however I drive mostly highway with cruise on.
IIRC Wisconsin has a lot of rolling hills. If that's your highway drive, you can probably increase your mpg by dropping the cruise control, and learning to roller-coaster the hills a bit. That is, you let your speed drop a bit going up - cruise control would give more gas to try to keep a constant speed uphill - then pick up speed on the downhills. This also could help with your AT shift points.
Old 01-04-2010, 06:57 AM   #12 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
A block heater will help with the over rich warm up as well.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 01-04-2010, 07:14 AM   #13 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
I'd be interested to see that flat underbody. I drive a minivan of a different make, and my underbody is far from flat with exhaust, suspension, fuel tank, crossmembers...
A belly pan is definitely on my list of improvements to do. I've done a temporary grill block, and will be doing a more permanent one. But adjusting the nut has, without a doubt, been the biggest factor in my mileage gains.
Old 01-04-2010, 03:33 PM   #14 (permalink)
check out
you might want to check out the seminars and mods list to see what mods have done to other vehicles like yours.
Drive shaft mod save fuel. dwtaylorpdx EcoModding Central 17 10-31-2009 01:38 AM
Hybridizing a 2-wheel drive pickup bennelson EcoModding Central 5 10-14-2008 11:53 AM
Drive Slower or Drive Faster behind a Semi? Which is more efficient? izanti General Efficiency Discussion 9 08-06-2008 04:43 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
