Old 08-06-2011, 03:49 PM   #21 (permalink)
photovoltaic panels will make an improvement so small it will be difficult to measure.
Let's say you could strap 50 watts of panel(s) on your car without making the aerodynamics worse (unlikely). That will save a tiny/modest amount of gas (based on reducing the field current to the alternator, and reducing the work needed to rotate the alternator).
But, there are other alternator losses, like belt friction and bearing friction that are still there even if the alternator is completely disconnected electrically.
As cool as pv panels are, they will not help your car any meaningful amount.
You could get more benefit from cranking in five more psi in your tires.
Finest regards,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
DIY Solar PV panels sold at Lowes NeilBlanchard Saving@Home 22 06-30-2014 04:24 AM
Replace sunroof with solar panels to power AC? Luxbg EcoModding Central 6 08-19-2009 10:23 AM
solar panels vs biodiesel dcb Fossil Fuel Free 6 05-23-2009 12:25 PM
Motor, battery and solar panels for a boat Wywern Fossil Fuel Free 11 02-17-2008 08:22 PM
