Old 03-05-2025, 06:35 PM   #31 (permalink)
They're smiling in the thumbnail, but if that hatch closed, I think they would not. I guess they'd have that little window below the spoiler?
I'm losing the struggle to enable NTP time synchronization.
techoverflow.net/2023/03/14/how-to-enable-or-disable-ntp-time-synchronization-on-the-raspberry-pi/
I successfully reset the time and date manually. ...to February, then every subsequent attempt erred.
After I restarted it finally took, and I could get Recent Posts working.
Old 03-05-2025, 07:06 PM   #32 (permalink)
90 day: 51.16 mpg (US)
You'd flip around the other way for actual sleeping. I never got the opportunity to sleep in the Prius, so I can't comment on comfort. At 6'2" I probably don't fit laying flat.
You know you've got to expose your machine to the dreaded Information Superhighway to get NTP working, right :P
Old 03-05-2025, 07:27 PM   #33 (permalink)
Overnighting in the Dasher was similar, but with two doors. A Beetle is easier IMHO.
The Dreaded Information Superhighway is what complains about the clock. At some point, I'll throw a fresh OS image onto a micro SD card and try to set it on first boot.
redpoint5 (03-05-2025)
Old 03-12-2025, 01:28 AM   #34 (permalink)
I would expect the Dasher to be much better to use as living.. err.. camping quarters than a Beetle
I'd much rather get a motorhome/campervan, or use a truck with a camper module, but this looks good too.
Old 03-12-2025, 06:43 PM   #35 (permalink)
How much fuel efficiency do cars lose when towing small trailers, not only from the increased wind resistance, but also rolling resistance?
Robert Smalls reported towing with his Prius C and "struggled to get 40mpg:" https://ecomodder.com/forum/showthre...s-c-30589.html Also, Old Mech shared a picture of his old Sentra, which had pretty flat hubcaps:
priusCpilot reported 46 MPG towing a trailer that sounded like it was 1/3 as heavy.
I don't remember the name from here, but JCP, Pale Malesian, and Basjoos ring a bell.
2016 Prius pulling a slick Husqvarna two-stroke bike, between 38 and 42 mpg with his Prius while towing the 800- to 900-pound load.
2022 Prius Prime towing a Grumman canoe with a 20-horse Tohatsu outboard motor on the back. No mention of MPG.
“People underestimate a car’s ability to do work, like pulling a trailer, and often buy vehicles that aren’t very sensible for day-to-day travel so that they can tow very light loads or utilize a truck bed just a few times a year."
2011 Prius with the 1.5-inch Prius Offroad [lift] kit, 205/65/R15 General Altimax RT45 tires, and stiffer rear coils. Pulls his ATV, dirt bike, and gear—as much as 2,300 pounds some weekends. It’s a regular thing, too, and he apparently gets 28 mpg when loaded to the gills.
"[I]f you’re regularly towing more than 2,000 pounds or so, it’s probably better to buy a bigger car."
“I used to hate the Prius as someone who loves to drive fast, loves watching motorsports, and drooling over high-performance vehicles, but I tell you what, I’m a mechanic myself and tend to lean toward more sensible things that aren’t overpriced and the Prius is my car,” Burnside raved. “This is my third one and I expect it to last 250,000+ miles like the last two did.”
https://www.thedrive.com/news/youll-...-towing-people
I saw many results on PriusChat and reddit, but the extra wheels don't seem to cause too much of a problem.
Old 03-20-2025, 12:56 AM   #36 (permalink)
Unless it's something really underpowered, and with a gearing which may not be so suitable for the task, most likely the toll on fuel efficiency won't be too bad to justify upgrading to a truck. No wonder I see so many econoboxes with trailers. Sure, tow ratings may vary for the same model according to the local regulations.
Old 03-20-2025, 02:30 AM   #37 (permalink)
Ingress-egress. The Beetle has a 2.5x6ft rack, while the Dasher had a shorter and wider space. More headroom with the platform at the level of the backbone tunnel instead of seat height..
Old 03-22-2025, 12:16 AM   #38 (permalink)
Didn't you fold the rear seat of the Dasher?
Old 03-22-2025, 01:03 AM   #39 (permalink)
Yes. Limited headroom under the hatch.
Old 03-25-2025, 01:30 AM   #40 (permalink)
If you could find a rare Brazilian aftermarket rear hatch which imitated the shape of a station-wagon, that would've solved the problem...
Or a replica of that Toppola camper.
