Old 05-03-2013, 01:38 PM   #11 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
^^^That'd be the one!
Sorry, I got myself distracted with garbage night and then working on a project for my car.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 05-03-2013, 04:10 PM   #12 (permalink)
Thanks. No frostbite!
It was not that hot. I wished that I had my insulated bag, I would have made it home with more of that unobtanium that we call ice.
Some of my decisions make more sense than others...
Old 05-03-2013, 10:15 PM   #13 (permalink)
radioranger
wouldnt a hot car be more aerodynamic? due to the less viscous air near the surface
Old 05-03-2013, 10:48 PM   #14 (permalink)
It stands to reason, but I do not know how much of a difference it would make, like this:
freebeard (05-04-2013)
Old 05-04-2013, 02:45 AM   #15 (permalink)
That sounds like a blown flap concept.
They fell out of favor in the 60's due the huge power requirement for the compressed air.
Old 05-04-2013, 02:43 PM   #16 (permalink)
Cornish
Many years ago I read a Popular Science article about making planes and trucks more aerodynamic by compressing air and releasing it in strategic locations. The article sounded like the theory was successfully tested, although I have not heard of it since, and would not have any idea how to track down the article. I looked through the first hundred Google results for "plane truck compressed air Popular Science" and, of course, it was a waste of my time.
I was just thinking though, if a low-pressure zone, like the bottom of your windshield, increases drag, and so does a high-pressure zone that pretend Ecomodders have on their side mirrors, would there be any gain by piping air from the top of the hood to around the mirrors. How much of the wake could you fill?
These are the things on my mind when I try studying for finals...
See if you can track down J.J.Cornish III.He was the chief aerodynamicist for Lockheed Aircraft and published a related paper with the American Institute of Aeronautics and Astronautics (AIAA).
Alex Tremulis wrote of him in the 1980s,believing that by now,all cars would be using this technology.
I have only one example of an aircraft with STOL capability,built in Japan,which uses an entire jet turbine engine to provide the necessary air volume for the wings to function.
Old 05-05-2013, 12:29 AM   #17 (permalink)
Sounds like the "augmentor wing" that NASA flew in the 80s. (70s?)
C-8A Buffalo Augmentor Wing Jet STOL Research Aircraft | Flickr - Photo Sharing!
-soD
Old 05-05-2013, 01:25 PM   #18 (permalink)
radioranger
how about spraying a less viscous gas onto the surface , like ? only be good for a short run however, On the boats they vent air under the boat for a pretty big difference in drag at moderate speed, i think volvo patented it maybe 15 years ago , used on quite a few high performance boats now I think formula yachts uses it, in the james bond move, the world is not enough there is a sport cruiser driven in a chase scene in teh very beginning, we have the identical boat at the marina where i work and it has huge slots midship to carry air under the hull, heard it makes around 15 % improvement. course not really applicable but interesting.
Old 05-06-2013, 11:33 AM   #19 (permalink)
One of the most innovative STOL designs ever conceived.
Custer Channel Wing
Custer Channel Wing - Wikipedia, the free encyclopedia
Old 05-06-2013, 12:09 PM   #20 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
The Russians reportedly have a supercavitating torpedo, named the Shkval. It apparently uses the combination of a specially shaped nose section, and a rocket engine, to achieve speeds of 200+ knots underwater. The nose section supports a bubble that envelopes the entire torpedo, which significantly reduces drag.
The Following User Says Thank You to t vago For This Useful Post:
radioranger (05-06-2013)
