Old 02-02-2011, 08:53 AM   #1 (permalink)
2 Stroke - 40% efficiency ICE - 100mpg
Check it out.
Saving the World Two Strokes at a Time at Hemmings Blog – Classic and collectible cars and parts
For a good demo, See:
Watch "Opposed Piston Opposed Cylinder Engine" Video at Engineering TV
The Following 3 Users Say Thank You to redneck For This Useful Post:
Ryland (02-03-2011), some_other_dave (02-02-2011), t vago (02-02-2011)
Old 02-02-2011, 06:32 PM   #2 (permalink)
That video says a lot more about the engine than the web page did. Thanks for posting it; sounds pretty neat if they can make it reliable!
I wonder what the thermo efficiency of a turbo-diesel is, anyway? Or for a two-stroke turbo-diesel?
-soD
Old 02-02-2011, 07:44 PM   #3 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Say what? 40% BTE will get them about 55mpg combined in something like a Prius, assuming they keep the engine in the same range of loads/speeds. 100mpg would require something about half the weight/CdA.
Old 02-03-2011, 07:31 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
It appears that this idea keeps showing up in the media, but never in vehicles...
New 2-stroke Diesel engine, cool link to Engineering TV
Opposed-piston opposed-cylinder engine claims 50% FE increase
Old 02-04-2011, 10:07 AM   #5 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
-soD
TDIs are around 40-45% efficient over a fairly wide range. Spark Ignition ICE aka Gasoline engine tend to be around 35-37% at peak efficiency.
I'm pretty psyched about the horizontally opposed engine, although I'm not too happy that they're diesel only, I suppose it could be adapted to alcohol if that ever takes off.
-Allch Chcar
Old 02-04-2011, 11:34 AM   #6 (permalink)
Oopps, I didn't realize that this was that old. (my bad)
Seeing that the military has first dibs, it will probably be quite some time before it is released to the general public, if ever.
The prospects of a small and efficent high horse power engine like this is still intriging to say the least.
Old 02-07-2011, 12:08 AM   #7 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Get back to us when you find a way to make a two-stroker pass the EPA HC emission standards.
Why do you supposed the two stroke engine disappeared from the road in the first place?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 02-07-2011, 03:44 AM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
Why 2-Stroke Direct Injection is a Big Deal
Bourke Engine
Old 02-07-2011, 02:19 PM   #9 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
What's your issue with diesels?
Old 02-11-2011, 06:11 PM   #10 (permalink)
Big Dave's Avatar
Two stroke, direct injection, uses a supercharger for scavenging rather than bottom of the piston, no need to mix oil and fuel.
You just described a 6-71 Detroit Diesel. Same thing with opposed pistons is a Fairbanks-Morse diesel. Detroits had a high power-to-weight ratio as diesels go. F-Ms will run on anything remotely oily. Neither was particularly clean.
4" Slam
