Old 02-06-2009, 07:47 AM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
'97 Civic running 14.2 Volts?
My '97 Civic HX runs at 14.2 volts just about always.
Seems a bit high to me.
Anybody else with a ScanGauge or other good monitor system can tell me what voltage their '97 Civic is running?
Coast long and prosper.
Old 02-06-2009, 08:17 AM   #2 (permalink)
chevynova - '88 Chevy Nova
90 day: 31.84 mpg (US)
Fit - '08 Honda Fit Sport MT
90 day: 39.63 mpg (US)
When charging you could see the voltage reading 13.8 -14.0 +. I don't recall personally seeing 14.2, but I wouldn't be too concerned with it.
Old 02-06-2009, 09:09 AM   #3 (permalink)
14.2V is normal.
Old 02-06-2009, 09:39 AM   #4 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I see 14.2-14.3 when the engine is running and charging. It's normal. It needs to provide a voltage ABOVE the nominal battery voltage for any charging to happen. If it only matches the battery (~12.5V), there will be no reason for any current to flow.
Old 02-06-2009, 03:37 PM   #5 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
I've seen 14.3V on my Neon, the colder the temperature the higher the voltage the alternator puts out.
Old 02-06-2009, 07:25 PM   #6 (permalink)
brucepick's Avatar
Gen-1 Insights
Thanks folks.
After posting my question I had the bright ideal to look in my Haynes book for this car. It says 13.5 - 14.5V. Mine runs at 14.2. I have no idea whether that info is generic or specific to that generation Civic but it's reassuring.
IndyIan wrote "the colder the temperature the higher the voltage the alternator puts out". Yes that's true - I've read that before elsewhere. Something about the battery's ability to accept charging voltage varying with temperature.
Old 02-07-2009, 11:48 AM   #7 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.06 mpg (US)
Bingo. I've seen as high as 14.7 volts on cold mornings. Once the engine is warm it will stabilize around 14.0-14.2.
Old 02-07-2009, 01:25 PM   #8 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I can confirm this but with my 94 VX. The cold starts in the morning result in a 14V reading on my gauge until the car warms up and has no accessories running it'll occasionally turn of the alternator and all the system voltage to drop to 13V.
Way more common in summer for the ECU to turn off the alternator and run 12.5-13V with accessories off.
Old 02-09-2009, 10:31 AM   #9 (permalink)
Pushrod - '02 Chevrolet Cavalier
It's normal. Enjoy the increased performance from your audio equipment
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Wanted: Civic HX 4 replacement or Civic shell needing an engine HDCaptain For Sale 1 03-14-2009 02:57 PM
Craigslist Milwaukee: '97 Civic HX lean burn love MetroMPG For Sale 0 02-05-2009 04:02 PM
What Tranny lube for '97 Civic 5-speed? brucepick EcoModding Central 11 10-07-2008 12:38 PM
