Old 11-11-2011, 02:19 PM   #1 (permalink)
speedometer off by 5 miles at 60mph
according to a gps app that shows mph, i'm doing 60,while the speedometer shows 65.if i got ,say 300 miles to a tank,what is my actual mileage?
Old 11-11-2011, 03:58 PM   #2 (permalink)
...beats walking...
...which do you "believe" is more correct, GPS or car speedometer? Both have intrinsic errors, the question though, is which is LEAST wrong?
...what vehicle? GM products are "known" for speedometers displaying 2 mph ABOVE their true value...but, the odometer is (supposedly) not affected by this difference.
Old 11-11-2011, 04:27 PM   #3 (permalink)
1987 toyota truck.
Old 11-11-2011, 05:12 PM   #4 (permalink)
...beats walking...
...1987 will almost certainly still be using direct cable drive from the transmission to a mechanical speedometer "head"--for these, the aftermarket sells "gears" the can be put "in-line" with the cable to compensate for tires, transmissions and axles affects on the speedometer readings.
Old 11-11-2011, 05:17 PM   #5 (permalink)
darcane's Avatar
Can you find a nearby section of freeway with odometer calibration markings? They have several near me in Washington, not sure how common they are elsewhere. But, you can compare your odometer to a 5 mile long section of road that is marked at precise, 1 mile increments. Use that to determine what percentage your odometer is off (which may or may not reflect the error in your speedometer).
Assuming the 60 actual miles = 65 miles indicated, you would need to multiply your indicated miles by (60/65) or .92
300 x (60/65) = 277 actual.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 11-11-2011, 10:57 PM   #6 (permalink)
Not where I live,near L.A
Old 11-12-2011, 12:28 AM   #7 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
i used my GPS to determine odometer error. I recorded the odometer readings at 20, 40, 60, and 80 miles, v. the GPS miles. Now, when I fill a tank, I multiply the odometer reading by the % error from my testing.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-12-2011, 07:28 AM   #8 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
It could also be tires. If your tires are worn down about 1/4 inch which is 1/2 inch in diameter it will show a ~2% error compaired to a new tire. Another thing is make sure you have stock size tires on if you want the speedo to be accurate
Old 11-12-2011, 08:35 AM   #9 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
My mileage from odo to gps was 2.8% different on many tanks of over 600 miles distance.
Speedo reads 1 high though.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 11-12-2011, 09:04 AM   #10 (permalink)
Pishtaco
SentraSE-R's Avatar
On my xB with OEM tires, the speedometer was 5% optimistic, but the odometer was 3.3% pessimistic. Now I'm running tires that are 5.31% larger diameter, and my speedometer is accurate, but my odometer is 9.9% pessimistic.
Darrell
