Old 02-23-2019, 11:55 PM   #11 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
I almost bought a Jeep Cherokee 9-years ago but an ice storm hit so I had to wait and ended up with my S-10 Pickup truck.
I sometimes wonder what my path of modifications would have been.
I'm pretty sure it would have a box cavity of some kind, maybe in the form of adjustable flapper vanes - like tail rudders canted inward located along the trailing edges of the boxy body.
With the ground clearance of the Cherokee I may have even gotten into making a belly pan in lieu of my multiple chin spoiler projects.
There's a lot of low hanging fruit when it comes to the Cherokee. One guy was able to get his to 25 mpg highway on a modest parts budget!
https://www.jeepforum.com/forum/f11/...5-ats-1551782/
Old 02-25-2019, 04:35 PM   #12 (permalink)
Yes, the looks are one reason I would get it. It is unique; none of the American XJs came with those.
I'll have to try that with the cardboard, although I'm not sure how I will measure the difference, or how I will attach it. Any suggestions?
It appears your hatch wraps to the point of aerodynamic separation. If your device has a rolled leading edge that you can pull over the edge of the hatch, then all you need is a detail that crimps it on.
http://www.vehicleclips.co.uk/fasten...ess-panel.html
You could box the three sides of the hatch and put a clear plastic fin on the taillight lens to fill down to the bumper. Voila! Boxed cavity.
Taylor95 (02-25-2019)
Old 02-25-2019, 11:46 PM   #13 (permalink)
That's an idea! And yes, the hatch opens at just the right spot to be able to do that
Old 01-15-2021, 12:40 AM   #14 (permalink)
It has been a long time but I am more serious about buying this spoiler now. I will definitely modify it so it angles downward some.
I am thinking about adding small fins on the outside edges of the spoiler to guide the air. In addition to this, I may add a lip to the spoiler to help decrease lift. Thoughts on this?
Old 01-15-2021, 01:22 AM   #15 (permalink)
You probably don't need to try to reduce lift - squareback shapes with a roofline basically parallel to the ground don't develop a lot of lift.
As has already been suggested, I'd experiment with different configurations first.
This took a lot of tweaking but ended up working pretty well (as far as I could tell; I didn't know about throttle stop testing then):
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (01-15-2021), Taylor95 (01-15-2021)
Old 01-15-2021, 01:09 PM   #16 (permalink)
spoiler
In addition to a any small drag benefit, for regions of the country which experience truly four-seasons weather patterns, that overhang might mean less snow and ice to clear off the rear glass.
Old 01-16-2021, 09:32 AM   #17 (permalink)
Was hoping the addition solved the boil up after the car. I have the same problem in my 13 golf..... ten minutes on a snowy or wet road and you can't see out the rear window for all the road grime from the rear. Vw's fix is to turn n on the wiper back there.
aerohead (01-20-2021)
Old 01-21-2021, 02:11 AM   #18 (permalink)
Keep us posted. I'm curious about your plan.
The Following User Says Thank You to mattrod For This Useful Post:
Taylor95 (01-21-2021)
Old 03-20-2021, 06:51 AM   #19 (permalink)
The company that makes those spoilers wanted $75 for shipping on top of $225 for the spoiler, so I decided I did not want to pay that. I am currently thinking about how I can make my own spoiler. I have some plexiglass laying around, so that may be an option if I can figure out how to attach it.
