Old 01-09-2015, 10:11 AM   #31 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Gets expensive and more complex as you get away from the current design standard quickly doesn't it. You can't get the trailer too low in the middle of the span either or it may have clearance issues with steep grade transitions.
How often have folks seen the single wheel setups in the states as oppposed to the double wheels on the trucks (the truck has 6 wheels instead of 10). I've seen a few new trucks set up that way. Its supposed to be more fuel efficient. Probably cost prohibitive to convert an older vehicle. I haven't seen any with the crosswind baffles in between the cab and trailer yet. I've seen several with a plastic shape on the trailer bottom that looks like a ramp. I assume its for aero? Wonder how much improvement that gleens.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 01-11-2015, 12:52 AM   #32 (permalink)
That's like making a bazillion wheelchair ramps instead of improving the wheelchairs. With airbagged suspension you can just raise the whole trailer.
Can also use liftgates which may also be used as a ramp for a more precise levelling to the dock. BTW I have already seen some docks which had built-in retractible ramps.
