Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-12-2017, 07:28 AM   #21 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Flushing ability has more to do with cistern height than anything. It's not about volume flushed but flow rate. Kind of like expecting to be able to flush a poo with a piss, a slow flush is useless. Think of water blasters using next-to-no water compared to a hose
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 09-12-2017, 10:45 AM   #22 (permalink)
Toilet tanks used to be on a 3 or 4ft standpipe with a pull cord on the lever. One wonders why they didn't return to that design with the low flow models.
Xist (09-12-2017)
Old 09-12-2017, 01:17 PM   #23 (permalink)
I thought that was negative though?
Old 09-12-2017, 03:48 PM   #24 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
That might be why the flapper valve is raised a number of inches off the bottom of the tank. The water below that point will never leave the tank...couldn't figure out what the point was. This is a good theory.
As of yet. I have yet to be able to slow it down, let alone plug it...quite impressed.
Old 09-12-2017, 06:33 PM   #25 (permalink)
I could ask my new landlord about raising the tank and putting in a padded backrest, but it would probably make more sense to ask what he wants to do before he installs the new toilet sitting in a box.
Old 10-26-2017, 06:07 PM   #26 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Xist, if you still have access to the old toilet, you could take the tank and see what happens when you fill half the waters area with cement or something lighter to drop the amount of water in tank by half while still getting good hieght and use a 4 inch pipe to keep the cement away from the flushing components. Then you put some little pieces of angle iron at the top of the pipe to give the water a twist to try and get it to shoot through the toilet faster!!
Then you take the composting toilet seats with the separate part for pee that then runs down a 1/2 inch pipe through the toilet so it doesn’t use any water for that anymore?!?
