Old 04-04-2011, 05:26 AM   #71 (permalink)
I think it's too steep.
Old 04-04-2011, 10:37 AM   #72 (permalink)
1995 Previa LE S/C Driver
You could try tacking...
Moving on:
orange4boy,
You DID save all your measurements/templates/plans, right? I think you may have something here with the ability to produce an aeromod package for other Previa owners-- maybe just the plans alone, or complete kits. One aeromodded Previa saves your tiny corner of the Earth-- 10 of them save ten tiny corners of the Earth (the Earth has a plethora of corners).
Old 04-04-2011, 02:38 PM   #73 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
If you are referring to the slope of the kamm, I did tuft testing with a chaser car (sorry no video) It looks steeper in the pic partly because of lens distortion and partly because you are seeing some of the side taper at that angle. I think it's ~12-14 degrees. What I really need to do is finish the lower sides and bottom and close off the end. I have too much work to do at the moment to be doing a lot of ecomodding.
I could pull some templates if asked. The attachment brackets are a PITA to fabricate but not impossible if you have some skill with sheet metal. Unless people see this as a custom green MPG mod, not so much a money saving mod then It might sell. It probably would pay for itself over time tho.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
aerohead (04-11-2011)
Old 12-25-2011, 10:03 PM   #74 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
I have been working on my Ford Aerostar van to improve aero but so far have only managed to do a partial under tray. Fallowing this thread has given be some new Ideas thanks.
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 256 09-11-2013 04:22 PM
Accordion Kammback for big rigs ? Cd Aerodynamics 36 02-27-2012 05:03 AM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 12:23 PM
Sedan Kammback? KJSatz Aerodynamics 10 09-28-2009 04:58 AM
Non-invasive mounting for kammback wagonman76 Aerodynamics 4 03-24-2009 06:15 PM
