Probably should figure out if the torque converter ever locks in lower gears. I think higher rpms = higher torque converter efficiency, but don't quote me on that one, it's just a hunch based on driving my mom's car.
I don't know if this is actually working, but when I drive an automatic I press the gas lightly to start, roll onto the pedal halfway as the car picks up speed, and as the rpm approaches 3000 I let off a little to coax a shift and then back on it a little, and then I take note of the rpm; Sometimes the transmission doesn't want to shift up, so I switch to neutral and then back, usually that coaxes an upshift, and then I put very little pressure on the pedal to keep it in the highest gear.
