Old 02-29-2012, 04:49 PM   #31 (permalink)
...beats walking...
...back to my 'original' point, which is:
1) EPA tests with 100% gasoline, not E10 <--- stated by others.
...and...
2) EPA tests with 91 octane fuel, not 87 octane which MOST engines are specified to use by their manufacturers.
...and, because most current engines can "adjust" operating conditions (ala' knock sensor) to achieve "optimum" results with varying fuel charactoristics (and thus performance)...the EPA tests are using higher-milage 'capability' 91 octane, not the lower 'capability' 87 octane that most people follow.
Old 02-29-2012, 04:55 PM   #32 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by Old Tele man View Post
...from slide 11 of this presentation:
http://www.arb.ca.gov/msprog/levprog...1/alliance.pdf
...it shows, in the right column, the current Federal (EPA) "test fuel" requirements. Note that AKI is always slightly less than the RON number, hence AKI = 91 octane, from RON = 93 octane.
That's a proposal for one standardized test fuel between the CARB and EPA. They are suggesting only testing with Premium grades and use 10% Ethanol.
I don't see how that means they only test with premium.
-Allch Chcar
Old 02-29-2012, 06:10 PM   #33 (permalink)
...beats walking...
...directly from the title of chart #11:
Current ARB and EPA Certification Fuels
Old 02-29-2012, 06:13 PM   #34 (permalink)
90 day: 29.78 mpg (US)
Originally Posted by Allch Chcar View Post
redpoint5, Ethanol is infact a more efficient fuel than Gasoline, it is simply not as energy dense. Strangely, Octane for blends from E50-E85 is about the same, 95 1/2 octane AKI, still better than pump gas at 93 but not what you'd expect. Plenty of the hotrodders, tuners, and engine builders swear by it. I've heard E85 is just shy of C16 leaded fuel but either way it is vastly underutilized in a FFV.
Good info; it helps to show how the math works out.
What I meant by less performance is less energy content, as you pointed out. People are primarily concerned with how much a tank of fuel costs and how far it will get them. In this way, petroleum is more efficient, otherwise we would all be driving E100 cars with high compression ratios and turbo chargers.
Maybe one day ethanol will be relevant, but this is not that day.
Old 02-29-2012, 11:00 PM   #35 (permalink)
EtOH
If you'll note, left is the California ARB which uses 91 octane. Right is the Federal certification which uses regular and premium grades.
Slide 10 you can see they are proposing the use of 91 octane for both.
That's confusing because to me, performance is power, octane, efficiency. MPG is a function of fuel economy.
Which one is more economic depends on the market and how efficient your vehicle is. For example, in the Midwest, Ethanol rack prices have dropped to <$2.50 a gallon while Gasoline is well above $3. Here I can buy E70 for $3.09 while Regular Gasoline is $3.59. If Ethanol drops 10 cents or Gasoline rises 10 cents then E70 make economic sense since I will only lose 15%-20% tops. Spring through fall has more Ethanol than winter so prices can actually drop leading up into summer.
But in places like Minnesota, Iowa, the Dakotas, etc they can get E70 for <$3 and Gasoline is the same.
-Allch Chcar
Old 02-29-2012, 11:58 PM   #36 (permalink)
...and that "...test grade Gasoline..." is 91-octane (mid-grade), not the typical 87-octane often recommended for most engines! Talk about "gaming" the EPA fuel-economy test system!!!
Strangely enough, I never use anything but regular 87 octane, yet am able to get well over EPA estimated mpg, despite living in a mountainous area which is not favorable to getting high mpg. So who exactly is "gaming" the system?
Old 03-01-2012, 01:26 PM   #37 (permalink)
...beats walking...
Specific example: operating a turbocharged engine on both higher octane & higher energy content fuel produces better FE because the computer and sensors allow the engine parameters to be "optimized" upward to exploit ALL the benefits of the higher energy (mpg) and octane (advanced idnition timing)...that's "gaming" the system.
Also, notice that ALL tests are done with NO electrical loads, save those during A/C tests only...but, YOU and I do drive at night, don't we?
e85, ethanol, mpg
