Old 02-15-2009, 02:06 PM   This thread is in the EcoModder Project Library | #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Windshield Wiper Cowl / Cover / Blocker Thingy?
SCROLL DOWN TO POST 21 (PAGE 2) FOR PICTURES!
Well, I FiNALLY installed a wiper cover, something I should have done a loooooooong time ago... but I never realized how easy it was. It basically hit me like a brick today. All I needed to do was cut a rectangle of cardboard and wedge it under the hood!
Haven't driven with it on yet, but I have to be to work in an hour, so I might have an update tonight around 8pm when I get home. Hopefully there won't be anything negative to update about.
ID:	2744   Click image for larger version
ID:	2745   Click image for larger version
ID:	2746   Click image for larger version
Old 02-15-2009, 02:28 PM   #2 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Damn, so more secure than my test : http://ecomodder.com/forum/showthrea...test-6155.html
Does your wipers are always functional at high speed ?
Tell us about your feeling : longer coasting, noise...
TIA,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 02-15-2009, 06:14 PM   #3 (permalink)
Schwartzejetta - '00 Volkswagen Jetta TDI GL
90 day: 52.87 mpg (US)
Don't forget -- does the snow wedge under there and make cleaning out by the wipers a pain?
Old 02-15-2009, 06:35 PM   #4 (permalink)
Does it need to be so big? Isn't it blocking your view?
Old 02-15-2009, 08:05 PM   #5 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
TIA,
Denis.
Yeah, I had seen your thread and had never thought of attaching it UNDER the hood until today. I have never had the problem of my wipers losing function at high speed.
So far, I have only driven to work and back with it on (15 minutes each way) and didn't notice anything.
Luckily, we have been having several warm days, then it lightly snowed yesterday. Hopefully we won't get much more for the rest of the year. When it is snow season, I always park with my wipers all the way up (shut off the car in mid-wipe) so I hopefully won't have that problem. If I do, I can just open the hood and take the airblock out to remove the snow.
Yeah... it is pretty big. I'm going to cut it down either tonight or tomorrow. I don't want to cut it down at the ends, but I am going to cut it down towards the middle. It has a very heavy curve to it because the passenger side wiper is mounted pretty far out and pushes the airblock out quite a bit.
Old 02-15-2009, 09:08 PM   #6 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Have you given any thought to just removing the passenger wiper?
I took mine off and then readjusted my drivers' side one to sit on the very bottom of the windshield. I have photos here:
Scientific Method meets Fuel Economy: Changes, Changes...
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 02-15-2009, 09:26 PM   #7 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
I use my wipers A LOT though... I doubt I would be able to make it with only one. Plus my windshield is cracked which causes gaps in the wiper run of the driver side. Luckily the passenger side doubles over most of the gap.
Old 02-18-2009, 10:35 PM   #8 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Did some... no, lots. Yes, did lots of highway driving today and it kindof flaps in the wind. Does this mean it's causing drag?
Old 02-18-2009, 10:41 PM   #9 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Assuming it flips up (???), each upward flip probably disrupts laminar flow over the windshield (???), so my guess is yes, it's causing drag at those times.
Old 02-18-2009, 10:52 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Any thing that flaps causes drag.
Note: My car is a Mercedes Benz 300SD which has the w126 body style. It was designed with windshield wipers that were stowed below the hood when not in use. Strangely its the only car body designed to do so.
Wiper cover test groar Aerodynamics 30 12-14-2019 10:35 PM
groar's 2001 Scenic Modding Thread groar EcoModding Central 4 11-25-2008 08:22 AM
Wiper area cover? wagonman76 Aerodynamics 3 06-28-2008 01:12 AM
One Windshield Wiper Instead of Two Wayneburg EcoModding Central 22 05-08-2008 02:04 AM
