Old 07-14-2009, 03:04 AM   #1 (permalink)
need large dia low profile high cfm electric fan
I am looking for large dia (2' or greater) low profile high cfm pulling (backside of the radiator) electric fan for my rig, see my profile.
on which vehicle(s) would that be a stock item i could source from the JY?
ty
john
Old 07-14-2009, 10:46 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
"low profile" will reduce the efficiency of the fan, and reduce the fan's CFM per RPM. But if you're cramped for space, do what you have to do.
The answer to your question would be "a truck". Probably a truck with a sideways engine. Minivan? Dodge Sprinter? Head on down to the U-pull and check it out. You'll probably come back with two small fans instead.
Old 07-14-2009, 10:47 AM   #3 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
Flex-a-lite does all manner of electric fans. It ain't cheap, but they're some of the best.
Have you checked the junkyards for a wrecked van like yours, that's maybe a decade or so newer? I think the fan on my gasser full-size Ford van is electric, and it's a 98.
Old 07-15-2009, 12:38 AM   #4 (permalink)
did some recon today what i found was in transverse V6 vans, the lumina vans had the largest about 18" dia and relatively low profile, fords had the second biggest made by whowouldathunked: Bosch. no mention of CFM anywhere
but they were all loop type. will have to try the "newer car" yard for only an additional $2 next time. how much conductive cooling happens to the "rods"
near the blast radius of a fan. 1/2" out, 1" or more ????
Electric Fan Conversion (Ford Ranger) allc0re EcoModding Central 13 05-01-2014 10:07 AM
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Ontario to Permit Low Speed Electric Cars on Roads, with Additional Rules SVOboy EcoModder Blog Discussion 8 07-16-2009 08:05 AM
Electric bill seems high...advice? ZachUA Saving@Home 39 03-12-2009 05:49 AM
