Old 06-06-2013, 09:23 AM   #21 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by slowmover View Post
Wow, D_D, I knew that pre-heating was a help -- and that my times s. distance would be different -- but that is one impressive graph commentary on the way you drive!!
That graph would be my like leaving home and essentially coasting downhill for 25-miles.
A lot of that is the engine-off coasting. That's the "sawtooth" signature that you see imposed on top of the traces--the engine cools down somewhat during the engine-off portions.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 06-06-2013, 12:18 PM   #22 (permalink)
2013 Matrix 2ZRFE - '13 Toyota Matrix
90 day: 38.48 mpg (US)
Toyota matrix 2013
Normal temps without any grill block = engine 87°C
With upper grill block:
outside temps lower than 25°C = engine 89°C
outside temps between 25°C and 30°C = engine 90°C to 95°C
outside temps 31°C+ = engine from 95°C to 98°C
I don't worry as long as the engine is in the 2 digits temp.
Old 06-06-2013, 02:18 PM   #23 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
how hot will I go? if my radiator fan is not running its good
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 06-07-2013, 05:42 PM   #24 (permalink)
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
At least on my two vehicles I found the blocking the decorative upper grill improved cooling as some of the air was coming out of the grill after it entered through the bottom intakes.
So my case the grill block resulted in ~1MPH increase and better cooling for both vehicles.
The Following 2 Users Say Thank You to pjbgravely For This Useful Post:
Piwoslaw (07-03-2025), RedDevil (06-07-2013)
Old 06-07-2013, 06:01 PM   #25 (permalink)
How did you figure out that?
Old 06-07-2013, 06:37 PM   #26 (permalink)
Team Mustang
For the Mustang I did 3 tank averages with block on and block off and the MPH increased 1 MPG with it on. I didn't know about the cooling effects until I hit a deer. When it was repaired I noticed the AC wasn't as cold as I remembered. When I reinstalled the grill block The AC was ice cold again. So the block helped with cooling.
For the Dodge truck, it had cooling problems climbing hills with heavy loads. After the block the temp gage never moves off normal and I even when climbed a large hill that is known to over heat trucks with a 800# load and the gauge never moved off normal. The MPG gain was tested with a scan gauge since it only gets filled every 3 months or so. The increase was around a 1/2 MPG but at 13 tops it is still a 3% increase. Even without the increase the grill block is still well worth the effort.
Old 07-02-2025, 04:30 PM   #27 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
How about winter grill block in summer?
https://youtu.be/kOPpJB12nrc?si=_9ykcnovUA0WU5dP
140km/h starts at 2:00 --> 90C no fans needed. I need about 32 Hp to keep that speed
150 km/h starts at 9:20 -->96c no fans needed I need about 40 Hp to keep that speed
car front explained 12:26
160 km/h starts at 14:04 --> 99C fans are on! I need about 47 Hp to keep that speed
170 km/h starts at 15:17 -->104c fans are on! About the max speed in that outside temperature. I need about 55 Hp to keep that speed.
https://www.linkedin.com/in/vesatiainen/
Developing next gen wheels and tires which will give 20% more range in Tesla Model Y.
The Following 4 Users Say Thank You to Vekke For This Useful Post:
Logic (07-02-2025), Piwoslaw (07-03-2025), RedDevil (07-03-2025), redpoint5 (07-02-2025)
Old 07-03-2025, 03:17 AM   #28 (permalink)
90 day: 59.86 mpg (US)
FWIW I completely cleared my grill block in this heat wave.
I saw reduced AC cooling and EGR use with the partial block. (I took out the first bar at the previous heat wave).
At 85 km/h the relative effect of AC on economy is substantial
I like to do without AC but at these temperatures not having AC becomes more than a nuisance. But 1 minute of AC on recirculation at full blast and then 5 minutes of no ventilation at all repeatedly yields both reasonable comfort and pretty good MPG.
grill block, mod, temperature
