Old 02-05-2010, 12:48 PM   #1 (permalink)
are you supposed to gap iridiums?
i have a 1990 toyota celica gt. i just got them NGK laser iridium for it at advance auto store today. i heard you are not suppose to gap iridiums or something? can some one confirm this to me?
thanks
Old 02-05-2010, 01:56 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
That is correct, the gap is pre-set, apparently the iridium is thin enough that gaping can scratch it off, or something like that, I think they also have a slightly larger gap, like you would get after a bit of wear on normal plugs.
The Following User Says Thank You to Ryland For This Useful Post:
bgd73 (03-19-2010)
Old 02-05-2010, 02:11 PM   #3 (permalink)
...beats walking...
...also, iridium metal is very brittle, and can break very easily, hence the "...don't mess with the gap..." mentality surrounding them.
...unless you have a special gapping tool.
The Following User Says Thank You to gone-ot For This Useful Post:
bgd73 (03-19-2010)
Old 02-05-2010, 03:39 PM   #4 (permalink)
thanks guys! now i know.. before i had a integra i got these same kind for it and gap it and broke the tip so that is why i had to ask before doing something stupid again.
Old 03-19-2010, 09:36 PM   #5 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I was going to go for iridiums...
but the single electrode platinums by bosch is on 4 years faultless..even with my goofy fuel air mistakes.
I did not know the iridiums were sensitive..not much talked about.
Old 03-20-2010, 12:44 AM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The center electrode on iridium and many platinum plugs is so thin that:
If you gap them, they will break.
That was a bad joke from "Field of Dreams", for those who aren't paying attention.
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 03-20-2010, 01:24 AM   #7 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Originally Posted by Christ View Post
"If you gap them... they will break."
fixed
Past Present Future?
Old 03-20-2010, 02:01 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hacken -
I have them. They com pre-gapped. Do not gap them.
CarloSW2
American Solar Energy Society
Old 03-20-2010, 02:23 PM   #9 (permalink)
...beats walking...
Originally Posted by cfg83 View Post
They com pre-gapped
...exactly; however, it's a good idea to "check" the gap as rough handling has been known to change the factory gap setting...but, NEVER attempt to re-set iridium gaps yourself unless you have the "proper tool"
...two of our three cars use iridium plugs, and I always "check" the gap setting before installation, but *if* it's incorrect, I just take them back to the dealer and request a new plug.
...I don't own the proper tool, but was able to borrow one once, hence my knowledge of its existance and use. And, "yes," I know about the fragility of the center iridium electrode by BAD experience--I broke one trying to reset the gap...and, since *I* was the one who broke it, I couldn't take it back and ask for a replacement, so I borrowed the proper tool (Champion CT-457).
I basjoosed my headlights today (sealed the surrounding gap) MetroMPG Aerodynamics 43 11-18-2013 07:55 AM
Civic VX & CX Spark Plug Gap flydude1221 EcoModding Central 9 07-01-2012 05:08 PM
Has anyone done spark plug gap tests? ziddey General Efficiency Discussion 29 06-07-2010 09:59 PM
Smoothing the gap between pickup cab and bed fourfa Aerodynamics 20 01-28-2010 12:49 AM
Taped shut hood to headlight gap. 99LeCouch Aerodynamics 1 04-03-2009 02:35 AM
